Subject: Dnn Tabs in ASP 3.0 web app
Alberto Mendia
10 Jul 2009 12:49 PM
I have a developed an application with ASP 3.0 and I want to add within links to pages made in Dotnetnuke that they contain developed modules with OWS.
Which is the form advisable in order to do this?
Should I create a portal that does not require authentication and to add to this portal so many pages DNN as needs?
10 Jul 2009 8:17 PM
You can certainly add links to a DotNetNuke site in your ASP site. You can't easily mix ASP pages and DotNetNuke within a single website.
Alberto Mendia
12 Jul 2009 6:26 PM
Ok, Thanks Joe.
Forums > DotNetNuke® > DotNetNuke® Questions > Dnn Tabs in ASP 3.0 web app
That will work.
DNN Creative Subscribe
