Subject: CSS Help
gbrown
10 Jul 2009 12:12 PM
While styling my mega menu I've run into an issue. When I make a page disabled the link is defaulting to some other class - looks like .commandlink.
Here is my class for styling the parent page links in my menu:
A.ParentMenu:link,a.ParentMenu:active,a.ParentMenu:visited{.....}
What can I add to that to ensure that disabled parent links are styled the same way?
I tried   A.ParentMenu:disabled   but that didn't work.
10 Jul 2009 8:19 PM
Which menu are you using?
gbrown
11 Jul 2009 12:31 AM
Thanks Joe - I figured it out. I forgot to add the base class - a.Parentmenu,.....  Had all the others and forgot the most basic one!  That solved my problem.
Folder permissions by saintX
That will work.
