Subject: howt to calculate page hit count?
Sakthi
10 Jul 2009 1:45 AM
Can any one know how to calculate page hit count in DNN?
Is there any inbuild module or existing module?
or
if we need to create a custom module then how?
Thanks in advance!
10 Jul 2009 7:14 AM
Do you want to show a counter on the page? If so, there are several modules available. I'd look first on snowcovered.com.
For general statistics, I prefer Google Analytics.
Forums > DotNetNuke® > DotNetNuke® Questions > howt to calculate page hit count?
Folder permissions by saintX
That will work.
