Subject: Login box on homepage
ashio
10 Jul 2009 12:55 AM
Is it possible to have the login and password box on the homepage, so members can type in their details and login in straight away, instead of clicking on the login in link (taking to separate page to login)?
10 Jul 2009 7:17 AM
Yes, just add the Account Login module to the page.
If you set it to be visible only to Unauthenticated Users, it will disappear when someone has logged in.
Forums > DotNetNuke® > DotNetNuke® Questions > Login box on homepage
Folder permissions by saintX
That will work.
