Subject: Where is the logout page in DNN v5.1
Germaine
10 Jul 2009 12:03 AM
Hey all.
May I know where is the logout page located in DNN 5.1? I would like to paste a script to prevent user from clicking after locking out.
10 Jul 2009 7:19 AM
There is no logout page, per se. There is a logout link that normally appears on every page.
You can set up a page to which the user is redirected after logging out.  That setting is on the User Settings page that you can reach from the Users page.
Germaine
19 Jul 2009 8:56 AM
Forums > DotNetNuke® > DotNetNuke® Questions > Where is the logout page in DNN v5.1
No, I still don't have a solution for this
RE: Fun? with styling of Home.aspx by dkemp@karrtuttle.com
Thanks so much for your help. The View Source tip, so simple, was effective. I went right to the p...
RE: How to slow down the menu by datamark
Thanks again Lee. I'll look into that garden menu again if it is that simple to install. No changes ...
RE: How to slow down the menu by leesykes
I can't remember without doing some digging into older skins what the parameters are for the animati...
RE: Non Standard Port with DNN 5+ by jncraig
In web.config ... "set UsePortNumber to true to preserve the port number if you're using a port numb...
Could you provide a bit more information? There should be some text that accompanies this.
RE: DotNetNuke 5.3.0 Released by leesykes
very interesting!
RE: How to upgrade core module? by leesykes
All you need to do is install the downloaded core module in exactly the same way as you would instal...
If the styles are not defined in a Text/HTML module, they might be defined in either the Header or F...
DotNetNuke 5.3.0 Released by jncraig
Joe Brinkman's blog has all of the details.  But, I found this interesting:New FeaturesTemplated Use...
RE: Removing View and Edit Buttons by mikehj
Joseph - you are right on the money. I missed a security setting on the page. Thanks
How to upgrade core module? by LeeWebDev
I can't believe this is so hard to find instructions for, but how do I upgrade to the latest version...
Thanks Lee, I still have older skins on some of my sites that are using the Solpart menu. So I was r...
RE: DataSpring Opt In Module - Scheduler Question by wynnjon
Thank you! Your advice and training is always so great and always appreciated!
Are you referring to the Nav menu rather than SolPartMenu?NavMenu has been default menu since around...
Yes this site uses standard registration.DataSprings Dynamic Registration replaces the original, it ...
RE: Using Xenu Link Sleuth to Spot and Improve External Links in a Domain by leesykes
So, are these external links that are linking into your website that no longer exist?If that is the ...
DNN Creative Subscribe
