Subject: How to prevent auser from multiple login.
Imran Hameed
03 Jul 2009 2:21 AM
Is there any way to prevent a register user from multiple login at the same time in the DNN.?
03 Jul 2009 10:24 AM
Forums > DotNetNuke® > DotNetNuke® Questions > How to prevent auser from multiple login.
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
