Subject: I have a problem with Mozilla
ebendelas
02 Jul 2009 9:34 AM
I have this problem. In a container (with name Banner 1) have this code: <%@ Control language="vb" CodeBehind="~/admin/Containers/container.vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.UI.Containers.Container" %> <%@ Register TagPrefix="dnn" TagName="ACTIONS" Src="~/Admin/Containers/Actions.ascx" %>
The container.css has this code: .containerbanner { border:1px solid #F60; background-color:#FFF; padding:2px 2px 1px 2px; margin-bottom:10px; width:100%; float:inherit } .banner_text .Normal{ font-family:Arial, Helvetica, sans-serif; font-size:12px; color:#3399CC; float:left; } .banner_text .Normal a{ color:#3399CC; text-decoration:underline; float:left; } .banner_text .Normal a:hover{ text-decoration:none; } My problem is with the Mozilla. In IE it is all OK. But the Mozilla don’t have the img in central of container. Thanks
03 Jul 2009 2:13 AM
I can't see any css code in here for styling images in your classes, perhaps you need to look at styling the img tag within the .banner_text class,
Forums > DotNetNuke® > DotNetNuke® Questions > I have a problem with Mozilla
RE: PayFlow Link by johnmurphy
Hi murphydolores, I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T...
RE: Background Music by cyborama
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out...
Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already...
Glad it's working!
Firefox SWF file by ce221
