Subject: FCKeditor
kiran
01 Jul 2009 3:38 PM
HI, i am facing problem with FCKeditor, i want certain role of people to allow permisions to upload image file, right now i see only admin can do that. some one give some idea Thanks
01 Jul 2009 5:17 PM
go to the admin menu / file manager
And in there you can specify which security roles have permission to upload files, for further information:
DotNetNuke File Manager
kiran
02 Jul 2009 10:42 AM
thanks lee, i got that...
That will work.
DNN Creative Subscribe
