Subject: Tokens associated with specific users
Knut Erik
01 Jul 2009 8:16 AM
Hello, Is there any way of using tokens associated with specific users, not only the user who is currently logged in? Instead of [User:Email], I would like to have [John:Email], for example. The reason I want this is that I would like to have a dynamically updated E-mail list on my site, so that when a user changes his email-adress, the list changes accordingly. Maybe there is another way of accomplishing this? Thanks for any advice, Knut Erik
01 Jul 2009 8:08 PM
If you want to create a list of users with their email addresses, I'd recommend using the Reports module. It will build the list dynamically whenever you visit the page that contains it.
Knut Erik
02 Jul 2009 8:10 AM
Joe, Thanks. I'm new to SQL. Would you happen to know what I should write in the query field to list Display Names and Email addresses for all users in a specific role? I have figured out how to do this for all the users, but not when I want just those who are members of a specific role. I would also like to sort the users alphabetically by Display Name, if that is possible. Thanks for your help, Knut Erik
03 Jul 2009 2:08 AM
I use this for selecting username, first, last name, email, role id and role name
SELECT Users.UserID, Username, FirstName, LastName, Email, UserRoles.RoleID, Roles.RoleName
FROM         Users INNER JOIN
                      UserRoles ON Users.UserID = UserRoles.UserID INNER JOIN
                      Roles ON UserRoles.RoleID = Roles.RoleID
WHERE     (UserRoles.RoleID = 3)
You will see the where clause is where Role id = 3, this is the newsetter security role on my site, you will need to look at the Roles table to see the id for the RoleName you require.
Or alternatively, just run the query and keep changing the roleid number until you find the correct one as it will display the role name in the results
03 Jul 2009 2:09 AM
ps. you may want to check out these tutorials:
Knut Erik
03 Jul 2009 3:04 AM
Fantastic! Just what I needed. You saved me a lot of time, as I am in a hurry to finish this before I leave on vacation. You have been very helpful. Thank you so much.
Forums > DotNetNuke® > DotNetNuke® Questions > Tokens associated with specific users
RE: PayFlow Link by johnmurphy
Hi murphydolores, I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T...
RE: Background Music by cyborama
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out...
Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already...
