rajani
| 14 Apr 2009 12:05 AM |
I have developed .net project and now i want to update it with DotNetNuke.Previous project contains ajax controls.Right now i m converting each aspx page to user control and then adding it to the page in DotNetNuke.But i m not able to give link to the page which is made in DotNetNuke.How i can do this?Where the pages are getting stored in dotnetnuke?I want to give link from user control to the page in DotNetNuke which also contains another user control
Joseph Craig DNN Creative Staff
 Nuke Master VI Posts:6139
| 14 Apr 2009 8:42 AM |
The pages in DotNetNuke are actually generated dynamically from entries in data tables. To link to another DotNetNuke page, you can use a link like http://yoursite.com/pagename.aspx. But, there probably are better ways to do this. Check out adefwebserver for a tutorial or two on navigating between pages. |
rajani
| 16 Apr 2009 12:14 AM |
| In dotnetnuke there are 3 tabs home,admin and host.i want to add one more "tab" .How i can do this? |
| 16 Apr 2009 9:41 AM |
Logged in as Admin or Host, look at the left side of the Control Panel for Page Functions. Click the Add link.
Take a look at these tutorials:
rajani
| 17 Apr 2009 3:23 AM |
Thanks for previous reply. I did it.
Our Project related with online shopping, contains different "web stores" and they have different url's. we were managing the the web stores by different "store id". when user hits the url, as per the url it will redirected to the different home pages and then all operations are done with the help of storeid.how i can do this in dotnetnuke 4.09.02?I want to display two different home page from dotnetnuke as per the url changes.plz help me out.
| 17 Apr 2009 7:45 AM |
One way that you might approach this is via Ifinity's URL Master and explicitly rewrite the incoming URL. I'm assuming the "store id" is embedded in the URL?
Another approach would be to put a custom module on the home page that looks at the URL and redirects.
I'd probably go with the first approach.
If there are more details on what you are doing, please explain more. There might be other alternatives.
rajani
| 18 Apr 2009 5:47 AM |
| right now we are running our project on localhost,so given the links like "http://localhost/dnn/GtplCart/Category/AddCategory/tabid/62/Default.aspx" this works very well.But the problem is, when we will upload the same pages in server it will not work.So what i can do ,so that there will not be the necessary to change the links when we will run our project on server ... |
| 18 Apr 2009 7:47 AM |
You should write your code to use relative links.
If the links are hard coded to include the base URL, you will have to edit that when you upload the site to a new server with a live URL.
rajani
| 06 May 2009 12:49 AM |
thanks for previous reply Now i m facing problem with fileupload control.i have used it in one of the control n written the code as fileupload1.hasfile...even if i m giving filename it gives error Object instance not set to an instance of an object....i tried other options like postedfile but it is not working n gives same error...what i have to do so the error will out.i want to give path for image file from file upload control n want to save it in the database...
I have taken checkbox in fieldset. On page there are 2 fieldset, one for billing address and other for shipping address,if i click the checkbox it would run javascript fuction and must fill the values from billing address to shipping address with same values.And the checkbox which i have taken is html control. i just want information copying from one fieldset to another with checkbox event.How i can do this??
rajani
| 08 Oct 2009 8:25 AM |
Good Evening Sir,thanks for previous all reply. I have a problem with httpcontext object. on home page i add value of url into the httpcookie . For log out page i get this saved value from httpcontext.current.Request.Cookie method. Suppose i have saved 'localhost/DNN' into cookie then httpcontext.current.Request.Cookie gives the url as 'localhost%2fDNN' so it gives error in my code. how to solve this problem so i get both url's have equal value. please help me. |
| 09 Oct 2009 8:32 AM |
You will need to decode the URL that you get from the cookie. "%2f" is the coded value for /.
.NET Framework Class Library HttpServerUtility..::.HtmlDecode Method (String)
Decodes an HTML-encoded string and returns the decoded string.
Namespace:
System.Web
Assembly:
System.Web (in System.Web.dll)
rajani
| 10 Nov 2009 10:46 PM |
Good morning sir, Thanks for previous all reply.i have a question that can i add more than one parent modules in single dnn web site. |
rajani
| 10 Nov 2009 10:48 PM |
| I am using dnn 4.09.02 version. |
| 11 Nov 2009 5:37 AM |
You can have more than one parent portal, yes.
rajani
| 12 Nov 2009 11:58 PM |
| Thanku sir |
rajani
| 16 Nov 2009 7:25 AM |
Good Evening sir, Pls tell me , does dnn skin and dnn themes both are same things?If no,how can I change the theme of dnn site. thank u. |
| 16 Nov 2009 4:26 PM |
Yes, those are the same thing. You change the "theme" by changing the skin.
rajani
| 17 Nov 2009 11:04 PM |
Good morning sir. Thanks for previous all reply.I have downloaded free dnn skin named 'DNNFlower'. It work fine in my site.I have problem in current date.On home page it shows wrong date i.e. previous day date.If I logged as 'Admin' and 'Host' then it shows correct date. pls tell me how to solve this problem. Thanks. |
rajani
| 18 Nov 2009 12:27 AM |
I have another question.I have added FAQ module in my dnn web site page. I have added two categories named 'shopping cart' and 'DNN' and a question-answer in each category.But it shows both questions sequentially one after another date-wise. Is it possible to see question and answer categoriwise .ie.'Shopping cart' category and all its questions ,'dnn' category all its questions? If yes,how do I set this in my module. Thank u. |
rajani
| 02 Dec 2009 7:23 AM |
Good evening sir, Thanks for previous all reply. We are facing some problems with different browsers while viewing our site. http://amookherjee.s20.dotnetsql.com/ Please open it in IE and Mozilla Firefox to check the difference. The main difference could be seen in the left pane of our website. If you suggest us the solution then we will be thankful to you.. |
| 03 Dec 2009 4:48 PM |
For comparison of the sites in IE and FF, it would help if you could post your skin file and css file.
For the date question (I seem to have miss this and the other one when you asked) please make sure that all of the time zone information is set correctly. You can set for the portal, and for the user. When not logged in, the portal's time zone is used. When logged in, the logged in user's time zone is used.
I just took a quick look at the FAQ module. I didn't see a way to display the categories separately. At one point, I used a third-party module that had that capability. You might want to look on Snowcovered for alternative FAQ modules.
rajani
| 04 Dec 2009 4:09 AM |
| thank you sir |
rajani
| 05 Dec 2009 2:11 AM |
Good afternoon sir, I have another question.'Mailchimp' is email marketing service.Can i use mailchimp in my dnn shopping cart web site? Which email marketing service used for dnn which is easy to use? |
| 05 Dec 2009 6:54 PM |
I'm not aware of a plugin for using Mailchimp with DotNetNuke. There are some email modules for use with DotNetNuke, including one from DataSprings.
rajani
| 18 Dec 2009 11:30 PM |
Good morning sir. Pls tell me,what is difference between uploading skin as a host and as admin? Both menu contain skin option. |
| 19 Dec 2009 4:19 AM |
Skins uploaded for host are available to all portals.
Skins uploaded by admin are available only to a single port.
But all of that has changed in Version 5 as only host users are allowed to upload skins.
rajani
| 19 Dec 2009 4:40 AM |
| Thanku Sir.when we apply skin there are two types of skin host and site.both are selected by default.pls tell me which one is selected,also there is apply to options portal and admin.both are selected by default.which one is selected and when? |
| 19 Dec 2009 5:18 AM |
I'm not sure if I'm answering your question but you should be able to select either of the skins.
The check boxes determine which skins should be displayed. If you check both boxes (the default) both types of skins will be displayed.
rajani
| 21 Dec 2009 12:37 AM |
Good morning sir. I have uploaded dnn site on dotnetpark site.All sites shows same IP address.(Shared IP).Now i want to access my web site from register domain that require ip address of perticular site.what is the ip address of that site or how can i access my site from register domain? |
Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:6011
| 21 Dec 2009 2:12 AM |
hello,
Normally, when you have purchased the domains, they will have a ControlPanel with a "DNS Namespaces" option.
You need to ask your hosting provider what are the DNS namespace settings for your website. You can then enter those details into the settings for your domain name.
In DotNetNuke, you will need to make sure you add the domain name as a portal alias (admin menu / site settings) (make sure you do not include the http:// when adding a portal alias)
