Subject: File Manager Upload (intermittent error)
dnnmq
26 Aug 2008 1:22 PM
DNN version 4.8.3 running on Windows Server 2003 Version 5.2 R2
NETWORK SERVICE has Full Control permission
This error comes up intermittenly when re-uploading a file using File Manager.
An Error Has Occurred When Attempting To Save The File \Portals\0\banners\banner_rotator.js. Please Contact Your Hosting Provider To Ensure The Appropriate Security Settings Have Been Enabled On The Server.
Like I said, it's intermittent: sometimes it works, sometimes it throws an error.  Immediately after it works, I would try to re-upload again and I would get the error.  A few seconds later, I try again, it works. Any ideas?  Thanks in advance for your help.
27 Aug 2008 4:12 AM
dnnmq
27 Aug 2008 1:29 PM
banner_rotator.js is only 3KB.
This behavior was reported after we upgraded from 4.3.4 to 4.8.3.
Before the upgrade, we created 2 test copies of the site.  We upgraded one of the test sites to 4.8.3 and kept the other test site at 4.3.4.  When we didn't see any issues with the upgrade, we proceeded to upgrade the live site to 4.8.3.
The intermittent error occurs on the 4.8.3 version on the live and the test site.  However, we haven't been able to reproduce the behavior
on the other test site that is still running version 4.3.4.
28 Aug 2008 3:04 AM
It sounds as though you do not have permission to upload js files using the file manager. To check this, go to the host menu/HostSettings/advanced settings/other settings/ file upload extensions - make sure js is added to the list.
dnnmq
28 Aug 2008 11:09 AM
Lee, your attention to this issue is truly appreciated because it's driving me nuts.
js is included in the File Upload Extensions.  The error is intermittent when uploading the SAME js file into the SAME folder.
The scenario I just tried with each step performed within seconds of each other goes like this:
1.  Upload banner_rotator.js --successful.
2.  Upload same banner_rotator.js --successful again.
3.  Upload same banner_rotator.js --successful again.
4.  Upload same banner_rotator.js --throws error.
5.  Click return, upload banner_rotator.js -- successful this time.
6.  Upload same banner_rotator.js --throws error.
04 Sep 2008 2:44 AM
FTP?! - lol - seriously though I'm not sure why this would occur. Try uploading the file until the error occurs, then check your event log files and see if an error is displayed in the logs - this may provide some further clues.
dnnmq
04 Sep 2008 1:02 PM
Lee,
Thanks for your suggestion about checking event log.  Here's what I did...
First, in site Admin>> Event Viewer, I clicked Clear Log.  Next, using Admin>>File Manager, I uploaded the js file and it was successful.   Then, I tried to upload the same js file and it displayed the error:
An Error Has Occurred When Attempting To Save The File E:\WebAsset\_______\Portals\0\banners\banner_rotator.js. Please Contact Your Hosting Provider To Ensure The Appropriate Security Settings Have Been Enabled On The Server.  (see attached screen print)
I then checked Admin>> Event Viewer and it’s still empty.  I logged into the server, went into Administrative Tools>Event Viewer.  There were no warnings nor errors logged in the Application or System view at the time I got the upload error.
I'm tempted to try upgrading to 4.8.4 to see if that error goes away.  Are there any issues with that version?  As I mentioned before, I couldn't reproduce this error on a dev site that still has the 4.3.4 version.
05 Sep 2008 4:04 AM
Have you tried to re-apply the permissions for Network Service across the entire installation files? - Just to make sure they are applied correctly.
I would also be tempted to upgrade to 4.8.4 - I have not come across any issues, but I would do a test upgrade on a local computer first to ensure everything goes smoothly.
05 Sep 2008 8:44 AM
dnnmq
05 Sep 2008 6:45 PM
Per Lee's suggestion, I removed NETWORK SERVICE from the website root then re-added it with Full Control permission.  I verified that folder E:\WebAsset\_______\Portals\0\banners and the banner_rotator.js file itself allows NETWORK SERVICE Full Control.  Then, I tried to upload the same js file.  It worked the first time but got the error when I tried to upload it again.
Joe, I'll wait until 4.9 is available to test the upgrade.
Thanks for assisting me with this issue.
dnnmq
26 Sep 2008 3:55 PM
Upgraded to 4.9 -- didn't resolve the problem.  The error still rears its ugly head intermittently.  Since file upload works sometimes, we'll just have to live with it.  Or as Lee jokingly suggested, ftp.
jack2304
28 Sep 2008 10:28 AM
This is Jack. I am using windows 2003 server When I purchased it is working well and presently it is showing error when I starts a program as the guarantee period is also over as it was purchased 3 years back is their any one that can help me to solve this problem. Please do it for me.
Jack
28 Sep 2008 6:00 PM
Is this a license issue? What is the exact error message?
Foremost Media
10 Jun 2009 4:01 PM
We are having the error on version 4.9. Is there a resolution? This not only appears in the File Manager, but in the FckEditor as well when attempting to upload a document.
"An Error Has Occurred When Attempting To Save The File C:\Inetpub\vhosts\<>\httpdocs\Portals\0\2008_2009_Test_Document3.pdf. Please Contact Your Hosting Provider To Ensure The Appropriate Security Settings Have Been Enabled On The Server."
11 Jun 2009 6:19 AM
hello,
That could be two possibilities, first of all you need to check that your DotNetNuke installation is configured to allow the upload of PDF files.
To do this, go to host menu / HostSettings
Advanced settings / other settings
File upload extensions: - make sure pdf is in the list
If it is, you will then need to contact your hosting provider and make sure they have enabled all of the correct security permissions on your DotNetNuke installation files and folders.
Taubinator
14 Nov 2009 5:08 PM
dnnmq ... I have exactly the same issue.  All the permissions are there and yet when you try to upload the same file in the same location I get the same error.  I can upload new files all day long and twice on Sunday.
Running the latest version of DNN 5 ... all installations are doing the same thing.
Did you get this resolved?  If so ... please tell me how.
dnnmq
15 Nov 2009 12:51 AM
Tuaubinator,
The issue still recurs. Our site is load balanced and the files are synched by robocopy which might be the cause of the intermittent error when updating a file while robocopy is synching.
Carlos Krefft
04 Mar 2010 3:52 PM
I had the same issue.
Cause:
There was 0kb on the drive hosting the portal.
Resolution: Freed up some space by deleting files.
Hope this helps.
Forums > DotNetNuke® > DotNetNuke® Questions > File Manager Upload (intermittent error)
RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97
Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ...
RE: ITextSharp by leesykes
Glad you got it sorted, what was the solution for anyone else searching for this problem?
RE: DataSprings Dynamic Forms Demo #20 Question by leesykes
Hello,This is not something I have explored yet, but as it happens I am going to be building a form ...
I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb...
RE: Shared Same content in Sub portals/ Childportals by leesykes
Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su...
RE: Should I be able to use a plain submit button in my module? by DiscoStu1975
Hi I used an ASP:button control originally and that produced exactly the same error with JS disa...
Hmmm, I think that I have seen something like this before, but I'm having trouble remembering the ex...
RE: Shared Same content in Sub portals/ Childportals by jncraig
There are modules available that will permit you to share pages, modules and user among portals in a...
RE: Should I be able to use a plain submit button in my module? by jncraig
Using a form submit button won't work. If you use an ASP:button control that will work as clicking ...
Hi Joseph Thanks for the response. I am using an html input of type submit, yes. When you say a l...
Are you using a form submit button? Try just just using a link and see if that works.
RE: Removing the filed by jncraig
I don't know an easy way to do that, short of editing the ascs file that displays that information. ...
RE: ITextSharp by jumatthey
Problem solved.
Removing the filed by kaustav_kar
Hi,I want to remove the option Display Name from this page. http://whydiet-com.stagemefaster.com/hom...
I have developed a module that is basically a simple data capture form. As I need the form to work w...
RE: Links by rajanijadhav
I have another question,in paypal integration for payment i have used [script removed]
Shared Same content in Sub portals/ Childportals by carlliw
Hello,I have a DNN parent portal and about 35 child/subportals. There are about 5 pages in all 35 c...
