| Backup Live Website without control panel? by ollep |
We are hosting with Re-Invent.com, a DNN host that doesn’t allow Control Panel access. We are ther... |
| RE: Keep Testing Skins by ollep |
| Hi Slowly sorting it out. www.goldcoastwebwiz.com/dotnetnuke/q1 The logo position is OK. B... |
| Some details re Logo possition:
HTML:div class="header">p>[LOGO]p>div>Found possitioning in "index_... |
| Pathing issues after setting up a domain name by harlowj |
| I had a site configured here: http://www.autorotate.com/portal/chl (all works good)I then decided to... |
| Hi Lee – and Joe
I’m Using DNN 4.5.5
I just installed Summer Breeze Skin and Template, and a... |
| RE: DNN - web services not working by jncraig |
| Do your web services have their own config files? Are they located in actual directories below the ... |
| RE: Installation on Vista by jncraig |
| You install Visual Studio according to the installation instructions. Once installed, you can "open... |
| Installation on Vista by jesp17 |
| I followed the how to install DNN to Vista, but what I miss is the intallation of visual studio. Can... |
| RE: Building a website with DNN by freedom22 |
| Hi Lee, Thanks for getting back to me. I understand now what you are saying, but I am still confuse... |
| RE: How to limit access to the admin menu.... by tallorder |
| Hi Lee Unfortunately I can't see how it works in reverse because the original process involved movi... |
| RE: Building a website with DNN by leesykes |
| Hello,Those classes refer to the menu, and therefore will not be specified in your skin.htm file as ... |
| RE: [HOUSEMENU] token not working by leesykes |
| Glad you sorted it, thanks, |
| RE: [HOUSEMENU] token not working by whred5 |
| OK I fixed myself after googling the problem. If anyone else comes across this situation you need t... |
| DNN - web services not working by paulrobinson |
| Good Afternoon,Please help. I have just installed my DNN web site to my dedicated live host machine... |
| HiI have been playing around with the Lazy_Days skin in an effort to learn css based skinning, I hav... |
| Lee or Joe, I meant that the skin.css file I downloaded has classes like .main_dnnmenu_item td w... |
| Lee, thanks for your reply. I did find the files. I am going through your tutorail, and in video7... |
| RE: page publish date by leesykes |
| I would suggest you view these tutorials:User Accounts new features User Accounts and User Settings ... |
| RE: page publish date by jncraig |
| I'm not quite sure that I understand you, but ... on the user accounts page there are these options:... |
| RE: Best so far for me by jncraig |
| I like the Snapsis CSS Nav Menu. You'll find it at Snapsis.com. |
