Subject: 3rd Party Module Integration - Profiles
bmurphy
20 Mar 2008 11:30 PM
I am wondering if it is possible to integrate DNN Fusion's My Profile 1.3 with Active Module's Active Forum and dnn core reg to avoid duplicating profile pages?
Anyone have any ideas on how to approach this?
21 Mar 2008 7:39 PM
If you dig around on DNN Fusion's web site, you'll find a few notes. I believe that My Profile can take some data from the Active Forums profile. It's not great, but there is some stuff there.
I've been playing with Smart-Thinker's UserProfile and UserGroups modules recently. There is some good stuff there, but there is lots fo good work to do in integrating modules.
Forums > DotNetNuke® > DotNetNuke® Questions > 3rd Party Module Integration - Profiles
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
