Subject: DNN 4.7 install - missing ASP.NET tab
rspls77
17 Dec 2007 4:14 PM
Uisng Win XP pro,  SP2 ,  32 bit processor
I am trying to install DNN 4.17 (clean install not upgrade) on my local PC. >NET framework 1.1. and 2.0 in insatlled on my PC.   on the IIS manager "ASP.NET " tab is missing .    I can't set my IIS to use .NET 2.0 and I am stock. I have checked my resigtry values for follwing keys and all have 2.0.0.0
HKEY_CLASSES_ROOT\CLSID\{7D23CCC6-A390-406E-AB67-2F8B7558F6F6}\InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FD5CD8B1-6FE0-44F3-BBFB-65E3655B096E} \InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FEDB2179-2335-48F0-AA28-5CDA35A2B36D}\InprocServer32\
I would appreciate any help.
Nuke Master I
Nuke Master I
17 Dec 2007 6:42 PM
I'm not that knowledgeable about installing and configuring IIS and ASP.NET. Hopefully someone who is will chime in. But, if something is missing, you might want to try to unistall and then reinstall IIS.
rspls77
17 Dec 2007 7:10 PM
I did uninstall and reinstall the IIS did not help.  Still  ASP.NET  tab is missing.
18 Dec 2007 2:34 AM
This is not something I have come across before either.  If I were approaching this I would search the microsoft related forums for any tips, if I couldn't find a solution I would use Virtual PC and create a separate install of windows XP and try again from a fresh installation.
I use virtual PC for all my development work now and if you are just starting out it is well worth looking into.
Let us know if you find a solution, thanks,
Lee
rspls77
26 Dec 2007 1:29 PM
Hello all
Here is how I solved it
1. Make sure there is an entry(folder) under  following keys names 2.0.0.0
2. Try Looking in [HKEY_CLASSES_ROOT\Typelib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] and [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] for the word "Path" in any values.  This was causing my asp.net Tab from not showing up. Replacing the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\0\win32 with C:\WINDOWS\\Microsoft.NET\Framework\v2.0.50727\AspNetMmcExt.tlb and the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\HELPDIR with C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727 worked for me when all other suggestions failed.  This is taking for granted that you have .Net 2.0 installed.  If you do not, look at these keys for a like machine that is showing the tab and use thoses setting for the above keys.
Note: if  regeedit does not allow editing a key, click on right mouse, permission, give full control for yourself then it will let you edit it.
Nuke Master I
Nuke Master I
26 Dec 2007 2:47 PM
I'm glad you found the solution!
27 Dec 2007 3:33 AM
Thanks for taking the time to post a solution, hopefully others will find this useful as well. - Happy nuking!
amuluri
09 May 2008 12:54 AM
Hi  all,
Am also not getting the ASP.Net tab in IIS . I tryed going your way of editing the key strings but the problem is that I couidint find the file in which this key is situated . Please help me in resolving this problem.
Thanks in advance.
Raju..
amuluri
Hi  all,
Thanks in advance.
Raju..
Nuke Master I
Nuke Master I
09 May 2008 9:38 AM
You might try uninstalling IIS, rebooting, and then reinstalling it. If you don't have the ASP.NET tab, check (Add/Remove Programs) to make sure that ASP.NET is installed. If it isn't, download and install from the Microsoft web site.
If none of these suggestions help, ask again.
Forums > DotNetNuke® > DotNetNuke® Questions > DNN 4.7 install - missing ASP.NET tab
Main Menu Bar by saliml
Is it possible to remove the Main menu Bar which is at the top of the page of Dotnetnuke sites which...
Different background image on each page by dtownsend
Hi,My graphic designers want to use a different background image on each page of a site (see attachm...
RE: Sync with module to module (announcement) by ryutopia
I think I have some sense.... When I add one external RSS feed site in News Feed Module for testing...
FCKEditor + Behavior by mgordon
Hi All,I'm having a frustrating time with the FCKEditor.  When I go to edit the text, it defaults to...
RE: Zip files getting corrupted when downloaded by jncraig
Hmmm ... let us know what you find.
RE: login module by jncraig
What I do is use the standard dnnUser and dnnLogin skin objects wrapped in some conditional coding s...
RE: Guestbook by jncraig
Recommendations, anyone?
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by jncraig
Something is wrong either with your IIS installation, or the way you created the IIS website.  Take ...
RE: store account login issues by jncraig
The key to fixing this is in your skin. Without knowing your skin design, it's hard to tell you how...
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by sattysir
I got the same error "This error can be caused by a virtual directory not being configured as an app...
store account login issues by mparrett
hello, my site is jewellers-online.net and as you can see my account module is in the left pane a...
RE: Zip files getting corrupted when downloaded by omorgan
Thanks Joe, I wondered if it was something like that but wasn't sure where to look. I'll go ahead...
Guestbook by jesp17
Hi,Is there also a good guestbook module for DNN?
RE: SMTP Setting error by sondlerd
I got it to work. I am actually using Windows 2003 Server. I had to set the address of the Host em...
login module by Bobbyjosephg
Hi   The login module becomes blank when the user successfully logs in.Is there any configuration se...
RE: Sync with module to module (announcement) by leesykes
I'm not sure what is happening there. When you go the the paret portal page it should automatically ...
I did as you mentioned. Could you tell me if this is normal? When I click the icon of RSS on one mo...
RE: UDT Module advanced search capability by jncraig
The answer I read from Sebastian Leupold is that you can't do this with the current version of the m...
You need to go into web.config and fix the setting for the maximum file size. It's default value is...
RE: Sync with module to module (announcement) by jncraig
Add an RSS module to the parent site. Configure it to collect from every child site. In answer t...
