Subject: DNN 4.7 install - missing ASP.NET tab
rspls77
17 Dec 2007 4:14 PM
Uisng Win XP pro,  SP2 ,  32 bit processor
I am trying to install DNN 4.17 (clean install not upgrade) on my local PC. >NET framework 1.1. and 2.0 in insatlled on my PC.   on the IIS manager "ASP.NET " tab is missing .    I can't set my IIS to use .NET 2.0 and I am stock. I have checked my resigtry values for follwing keys and all have 2.0.0.0
HKEY_CLASSES_ROOT\CLSID\{7D23CCC6-A390-406E-AB67-2F8B7558F6F6}\InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FD5CD8B1-6FE0-44F3-BBFB-65E3655B096E} \InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FEDB2179-2335-48F0-AA28-5CDA35A2B36D}\InprocServer32\
I would appreciate any help.
Nuke Master I
Nuke Master I
17 Dec 2007 6:42 PM
I'm not that knowledgeable about installing and configuring IIS and ASP.NET. Hopefully someone who is will chime in. But, if something is missing, you might want to try to unistall and then reinstall IIS.
rspls77
17 Dec 2007 7:10 PM
I did uninstall and reinstall the IIS did not help.  Still  ASP.NET  tab is missing.
18 Dec 2007 2:34 AM
This is not something I have come across before either.  If I were approaching this I would search the microsoft related forums for any tips, if I couldn't find a solution I would use Virtual PC and create a separate install of windows XP and try again from a fresh installation.
I use virtual PC for all my development work now and if you are just starting out it is well worth looking into.
Let us know if you find a solution, thanks,
Lee
rspls77
26 Dec 2007 1:29 PM
Hello all
Here is how I solved it
1. Make sure there is an entry(folder) under  following keys names 2.0.0.0
2. Try Looking in [HKEY_CLASSES_ROOT\Typelib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] and [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] for the word "Path" in any values.  This was causing my asp.net Tab from not showing up. Replacing the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\0\win32 with C:\WINDOWS\\Microsoft.NET\Framework\v2.0.50727\AspNetMmcExt.tlb and the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\HELPDIR with C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727 worked for me when all other suggestions failed.  This is taking for granted that you have .Net 2.0 installed.  If you do not, look at these keys for a like machine that is showing the tab and use thoses setting for the above keys.
Note: if  regeedit does not allow editing a key, click on right mouse, permission, give full control for yourself then it will let you edit it.
Nuke Master I
Nuke Master I
26 Dec 2007 2:47 PM
I'm glad you found the solution!
27 Dec 2007 3:33 AM
Thanks for taking the time to post a solution, hopefully others will find this useful as well. - Happy nuking!
amuluri
09 May 2008 12:54 AM
Hi  all,
Am also not getting the ASP.Net tab in IIS . I tryed going your way of editing the key strings but the problem is that I couidint find the file in which this key is situated . Please help me in resolving this problem.
Thanks in advance.
Raju..
amuluri
Hi  all,
Thanks in advance.
Raju..
Nuke Master I
Nuke Master I
09 May 2008 9:38 AM
You might try uninstalling IIS, rebooting, and then reinstalling it. If you don't have the ASP.NET tab, check (Add/Remove Programs) to make sure that ASP.NET is installed. If it isn't, download and install from the Microsoft web site.
If none of these suggestions help, ask again.
Forums > DotNetNuke® > DotNetNuke® Questions > DNN 4.7 install - missing ASP.NET tab
RE: Assign a css id to a module. by corourke
Thanks for the suggestion jncraig. I've made the suggestion: http://support.dotnetnuke.com/issue/Vie...
RE: Host menu gone? by vijaymoharle
Hi, Host is  menu is  available for  Superuser. When you  install DNN it will ask for  New Admin a...
dotnetnuke compiler error by wdarnellg
I am trying to transfer my dotnetnuke files from localhost to my live account. I have followed the s...
RE: Assign a css id to a module. by jncraig
I agree. Why don't you make that suggestion at dotnetnuke.com.
RE: Document management Modules by jncraig
I'm not aware of a module with all of these features. If you find one, please let us know.
RE: how do i get my home link to work.... by jncraig
Can you ask this again. I don't understand the issue.
RE: Default Events Module XHTML by emedia
I can't seem to locate the Visual Studio Solution file for the Events Module, I know most modules no...
how do i get my home link to work.... by cipher2079
how do i get my home link to work again, I am trying to get back into web building and I complete fo...
Hey guys,I'm new to DNN and have been trying to make a specific install of DNN XHTML compliant.  Gen...
How can I implement .net forms authentication in DNN? by pvirk
Hello,I am in the process of migrating an existing asp.net website over to Dot Net Nuke.  This websi...
Fixing Ugly URL's by digitaldoom
I've noticed that the QueryStrings in DNN (with Friendly URLs turned off) show Tabid=XXX.Is there an...
RE: Host menu gone? by digitaldoom
I had this problem also... My whole Host account is gone. When I login with Admin and I view a...
That's what I've been doing so far however that adds extra divs which isn't the most semantic way to...
Editing Blog Module to say News instead of Blog by omorgan
Hello,I'm trying to find where I can edit the blog module from saying Blog to make it say News. My b...
RE: Document management Modules by jfitzgerald
Ideally the following Check in\ out facility – Giving audit trail of who has ‘checked out’ the do...
What functionality would such a module have?
RE: control panel keeping rolling up by jncraig
Well ... I haven't seen this problem in IE, so your job might not be over ...
Hi Guys,I'm trying to find out if dnn has an advanced document management module?Can anyone help??Ma...
RE: control panel keeping rolling up by rizwan7705
thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfo...
RE: Main Menu Bar by jncraig
If you learn a little bit about skinning, you can do this easily by removing those controls from the...
ihostasp
