Subject: DNN 4.7 install - missing ASP.NET tab
rspls77
17 Dec 2007 4:14 PM
Uisng Win XP pro,  SP2 ,  32 bit processor
I am trying to install DNN 4.17 (clean install not upgrade) on my local PC. >NET framework 1.1. and 2.0 in insatlled on my PC.   on the IIS manager "ASP.NET " tab is missing .    I can't set my IIS to use .NET 2.0 and I am stock. I have checked my resigtry values for follwing keys and all have 2.0.0.0
HKEY_CLASSES_ROOT\CLSID\{7D23CCC6-A390-406E-AB67-2F8B7558F6F6}\InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FD5CD8B1-6FE0-44F3-BBFB-65E3655B096E} \InprocServer32\
HKEY_CLASSES_ROOT\CLSID\{FEDB2179-2335-48F0-AA28-5CDA35A2B36D}\InprocServer32\
I would appreciate any help.
17 Dec 2007 6:42 PM
I'm not that knowledgeable about installing and configuring IIS and ASP.NET. Hopefully someone who is will chime in. But, if something is missing, you might want to try to unistall and then reinstall IIS.
rspls77
17 Dec 2007 7:10 PM
I did uninstall and reinstall the IIS did not help.  Still  ASP.NET  tab is missing.
18 Dec 2007 2:34 AM
This is not something I have come across before either.  If I were approaching this I would search the microsoft related forums for any tips, if I couldn't find a solution I would use Virtual PC and create a separate install of windows XP and try again from a fresh installation.
I use virtual PC for all my development work now and if you are just starting out it is well worth looking into.
Let us know if you find a solution, thanks,
Lee
rspls77
26 Dec 2007 1:29 PM
Hello all
Here is how I solved it
1. Make sure there is an entry(folder) under  following keys names 2.0.0.0
2. Try Looking in [HKEY_CLASSES_ROOT\Typelib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] and [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}] for the word "Path" in any values.  This was causing my asp.net Tab from not showing up. Replacing the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\0\win32 with C:\WINDOWS\\Microsoft.NET\Framework\v2.0.50727\AspNetMmcExt.tlb and the TypeLib\{A4CA8810-6E46-36FF-A048-B7FD564742F8}\2.0\HELPDIR with C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727 worked for me when all other suggestions failed.  This is taking for granted that you have .Net 2.0 installed.  If you do not, look at these keys for a like machine that is showing the tab and use thoses setting for the above keys.
Note: if  regeedit does not allow editing a key, click on right mouse, permission, give full control for yourself then it will let you edit it.
26 Dec 2007 2:47 PM
I'm glad you found the solution!
27 Dec 2007 3:33 AM
Thanks for taking the time to post a solution, hopefully others will find this useful as well. - Happy nuking!
amuluri
09 May 2008 12:54 AM
Hi  all,
Am also not getting the ASP.Net tab in IIS . I tryed going your way of editing the key strings but the problem is that I couidint find the file in which this key is situated . Please help me in resolving this problem.
Thanks in advance.
Raju..
amuluri
Hi  all,
Thanks in advance.
Raju..
09 May 2008 9:38 AM
You might try uninstalling IIS, rebooting, and then reinstalling it. If you don't have the ASP.NET tab, check (Add/Remove Programs) to make sure that ASP.NET is installed. If it isn't, download and install from the Microsoft web site.
If none of these suggestions help, ask again.
Forums > DotNetNuke® > DotNetNuke® Questions > DNN 4.7 install - missing ASP.NET tab
RE: [Server Error]This error can be caused by a virtual directory not being configured as an application in IIS. by arm
Posted By mnaoj on 04 Dec 2008 11:46 AMError 1 It is an error to use a section registered as allowDe...
How to Create Module : by hassangas2003
this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old pro...
Background colour by petecarrick
Hi,Sorry if this is a real dumb question, I've been experimenting with the Vortex skin and I have ch...
RE: Horizontal menu vertical borders by petecarrick
That worked perfectly, thanks very much Lee.Pete
Change Login Page by edeakin
Hey guys it’s me again. Great work on session 46 keep up the great work! I want to be able to add m...
RE: Module Wrapper & Tab Aggregator?? by gbrown
Found the Ajax Module Wrapper from Gumbosoft. Bought it and tried it - it works inside of Tab Aggreg...
Has anybody tried to place a Module Wrapper module from ZLDNN inside a Tab Aggregator module from DN...
RE: SWF Tutorial Conversion by raymueller
Thanks and I will continue to research. Each of the applications pick up the introduction (~ 20-25 s...
RE: Please do review by leesykes
There are a couple of things that you could look at:Initial page load time of the sites was slow, t...
RE: Module Development - Settings Page by leesykes
thanks for letting us know the solution and if there's anything else we can help out with please let...
RE: SWF Tutorial Conversion by leesykes
not sure, its not something I have tried, the swf should convert, perhaps its worth googling around ...
RE: not been able to download videos by leesykes
RE: Styling the main menu by leesykes
When you add code to your skin.css file, make sure you press CTRL+F5 to reload the page and reload t...
RE: Horizontal menu vertical borders by leesykes
To find the id of the menu item, use the web developers toolbar for Firefox, go to information menu...
RE: Module Development - Settings Page by HMDevelopment
Hello Lee. No thanks -- I have still earned value from this site. I did quite a few 'video' tutor...
RE: Can I modify the Default Events module only for a Portal? by jncraig
If you create a skin for your site, it will apply only to your site.  Also, portal.css applies only ...
RE: How to prevent auser from multiple login. by jncraig
RE: Display main menu and sub menus in different locations by jncraig
I would recommend that you study our tutorials regarding skin development as a good start.The exact ...
I have been trying to convert some of the older SWF tutorials to a format that I can load on my Zune...
