Subject: adding venders via the host
chaloum
10 Dec 2007 8:47 PM
I have a major problem with banner advertising, I can add banners to a vendor on the host/vendor area
I dont have a problem in the admin/vendor
when I try to add a banner to a vendor in the host area DNN tells me I dont have permissions to view the file on the portal??
I can view the file in any number of ways using the host account but not the vendors??!!
What do I need to do the get this to work
thanks
Forums > DotNetNuke® > DotNetNuke® Questions > adding venders via the host
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
