Subject: Customer Dnn module search not working
rahimali
04 Dec 2007 11:44 AM
Hi Guys,
Customer module search not working
I have developed a Custom module in DNN 3.3.7.To make my module searchable, I have implemented the Isearchable interface. But my search is not working. My code is as follow
 Controller Class Code
        Public Function GetSearchItems(ByVal ModInfo As Entities.Modules.ModuleInfo) As Services.Search.SearchItemInfoCollection Implements Entities.Modules.ISearchable.GetSearchItems
            Dim colProducts As ArrayList = ListProducts(ModInfo.PortalID, ModInfo.ModuleID)
            Dim searchItems As Services.Search.SearchItemInfoCollection
            Dim productInfo As TFPProductInfo
            For Each productInfo In colProducts
                Dim searchItem As Services.Search.SearchItemInfo
                searchItem = New Services.Search.SearchItemInfo(ModInfo.ModuleTitle & "-" & productInfo.Prd_Name, "Category: " & productInfo.Cat_Name & ", " & productInfo.Prd_Descirption, 2, productInfo.Prd_DateAdd, productInfo.ModuleID, productInfo.PortalID.ToString, productInfo.Prd_Descirption)
                searchItems.Add(searchItem)
            Next
            Return searchItems
        End Function
ASCX Code
            ' included as a stub only so that the core knows this module Implements Entities.Modules.ISearchable
        End Function
I also done some manually entries in database table “DesktopModules” against my module definition. Which are as follow
SupportedFeatures=”3”
BusinessController=”Technologyfootprints.DNN.Modules.TFPProduct.Business.TFPProductController,Technologyfootprints.DNN.Modules.TFPProduct.Business”
I have search a lot on internet regarding my problem but could not resolve. Please help me out in resolving this problem.
Thank in advance
Waiting your response
Forums > DotNetNuke® > DotNetNuke® Questions > Customer Dnn module search not working
RE: Database error by derpir
