Subject: Affiliate management Software
CREWealth
31 Oct 2007 1:56 PM
I want to set up an affiliate program for my membership site.
( Affiliate program= other send members to me and I pay them per member)
I can't find any DNN modules for affiliate programs.
Do you know of any software that is compatible with DNN?
Jackie Lange
www.CREWealth.com
Forums > DotNetNuke® > DotNetNuke® Questions > Affiliate management Software
RE: Pop up window by jncraig
Pop up window by yerann
