Subject: 4.02 to 4.03
youngboy
29 Apr 2006 10:49 AM
Is the installation the same for ver 4.X updates as it was for 3.X versions per the video you did?
29 Apr 2006 12:03 PM
Yes it should be the same as long as you are upgrading v4. If you are upgrading from v3 to v4 further changes will have to be made.
Just make sure you copy all of the details required from your web.config file and as always test the upgrade process out on a localhost installation first. - This way you can double check if you've missed anything and test for any module problems etc. (There shouldn't be any, but you never know!)
Before you attempt it on a live site, make sure you backup everything.
youngboy
01 May 2006 10:16 AM
Thank you for the answer. They really ought to consider changing how you do a simple minor upgrade.
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
RE: Style sheet does nothing by andorz
Oh. I was told to do that in my thread at the dotnetnuke.com forum. http://www.dotnetnuke.com/Commun...
