Subject: validation control won't work when using javascript to assign value to listbox?
lionelluo
27 Apr 2006 10:14 AM
Hi, I have a text box and DropDownList control and a validation control,
When user entering a number in the text box, based on the entered number,
the dropdrownlist value will change
(document.getElementById('dnn_ctr-1_Register_ddReferral').value =
document.getElementById("dnn_ctr-1_Register_txtReferral").value;) and the
validation control will valify the dropdownlist if it's empty.
I found there is a problem the server side Page.IsValid will always return
false and ?ddReferral.selectValue is empty. But it works fine if I manually
pick a item from the dropdownlist.
What's the problem, do I need to chagne some value status after I use
javascript to assign value to the dropdrownlist control? Please help. Many
thanks.
Forums > DotNetNuke® > DotNetNuke® Questions > validation control won't work when using javascript to assign value to listbox?
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
