Subject: How to stop a redirect after user registration?
ndbarss
30 Jun 2007 12:08 PM
I am trying to figure out how to stop the user from being redirected to the user page after they register for the site.  We would prefer that it work like the login feature, where it returns the user to the page they clicked on a feature that would require login.
Right now, an unregistered user would click on the item and be taken to the login page where they would click on the register button.  I want them to be returned to the original page after they have finished.
Is it possible?  Any ideas?
Forums > DotNetNuke® > DotNetNuke® Questions > How to stop a redirect after user registration?
Glad you sorted it, thanks,
