Subject: List box on registration page
traccer
27 Jun 2007 8:06 PM
im adding list box on registration module?
my question is how to add list name from manage
profile properties,or how to put the name in to the list box,
dont you have a tutorial somewhere around here that discusses,
thanks
Forums > DotNetNuke® > DotNetNuke® Questions > List box on registration page
RE: Database error by derpir
