Subject: aspx pages
rgf21
26 Apr 2007 11:05 AM
How can I use CType(Settings("reposit"), String) in an aspx page that I created?
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
