Subject: Problem Domain,Address Bar and Images
traccer
20 Apr 2007 11:50 PM
hi ;
My question is, what the meaning the first Poratl Alias lower the http alias, A simple forwarding page in the root is not sufficient. Enter a Portal Alias on the Site Settings page that looks like this: www.iserver/site3 where dnn is the dotnetnuke install directory.  icreate the another portal using www.iserver.com then, I upload my site (www.iserver.com) the problem is ; i cannot see the image, but the header of image i can see it, from the root directory portals/0,all images is the one plays say it  , and the second question, my link in the lowerside is error ;
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL: /iserver/Default.aspx
Is there more indepth docs on this (and related issues) on the web somewhere?
thanks
Forums > DotNetNuke® > DotNetNuke® Questions > Problem Domain,Address Bar and Images
RE: Server Application Unavailable from localhost by picoallen
OK, I've got things working better now. Not sure why though as I lost track while following all the ...
e-Survey? by mgordon
I need a module that will do the following:When a person comes to a specific page (recreation guide ...
