Subject: Object cannot be cast from DBNull to other types
radhakrishan
02 Mar 2006 2:12 PM
When  I go onto my website, Im have this error message. I really don't know what I have done wrong. For this website im using access database(dotnetnuke).
Can u pls help.
See error message below:
Object cannot be cast from DBNull to other types.
Exception Details: System.InvalidCastException: Object cannot be cast from DBNull to other types.
Source Error:
Stack Trace:
[InvalidCastException: Object cannot be cast from DBNull to other types.]
System.DBNull.System.IConvertible.ToInt32(IFormatProvider provider) +48
System.Convert.ToInt32(Object value) +36
DotNetNuke.PortalSettings.GetPortalSettings(Int32 TabId, Int32 PortalId) +7053
DotNetNuke.PortalSettings..ctor(Int32 tabId, Int32 PortalId) +253
DotNetNuke.Global.Application_BeginRequest(Object sender, EventArgs e) +759
System.Web.SyncEventExecutionStep.System.Web.HttpApplication+IExecutionStep.Execute() +60
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +87
Version Information: Microsoft .NET Framework Version:1.1.4322.2300; ASP.NET Version:1.1.4322.2300
03 Mar 2006 5:08 AM
I can't tell from that what the error could be. - Is this after creating your own module.
It seems as though there is a Null value in a table somewhere that is causing problems.
Have a look in Your Admin/Log files to see the error & it should tell you which module is causing
the problem, you might be able to track it down from there.
Forums > DotNetNuke® > DotNetNuke® Questions > Object cannot be cast from DBNull to other types
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
RE: Style sheet does nothing by andorz
Oh. I was told to do that in my thread at the dotnetnuke.com forum. http://www.dotnetnuke.com/Commun...
