Subject: create customized module for file-upload
ccflau
01 Mar 2006 12:33 PM
hi there, i am trying to use DNN to build a webpage which allows users to upload files(.jpg & .pdf) to the webserver. is there any existing DNN module which can do the job and if not, what's the best approach?
thank you in advance!
01 Mar 2006 5:02 PM
Yes, the Repository module covers this and is a free module that comes as a core module with DNN. To download it go here:
http://www.dotnetnuke.com/Default.aspx?tabid=831
and to ask any questions regarding the module go to this forum
Forums > DotNetNuke® > DotNetNuke® Questions > create customized module for file-upload
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
