Subject: Installation Complete but unable to login
jo woods
11 Jan 2007 10:22 AM
I'm trying to set up ddn 3.1.0 on my local server. After a few errors the installation took place and the default ddn website appeared, great, then I tried to login as admin&host with password admin/host and it doesn't respond? It just takes you from the login screen back to the home page but with no admin controls etc. seems strange, have you come across this before?
thanks alot,
jo
11 Jan 2007 10:42 AM
hello,
I have come across this before, you need to check a couple of things.  First of all some of the browsers can be funny when logging in to a local host installation.  Internet Explorer should be fine but I have found Mozilla Firefox to be the best browser when working on a local host installation.
The next thing to check is your firewall settings, if they are set too high you may find that you cannot login.
Thinking about it, I recall when I was using Internet Explorer I had to switch off the firewall to get access, but with Firefox I can leave the firewall enabled and still get full access to the local host installation.
Hope this helps, thanks,
jo woods
11 Jan 2007 11:02 AM
hi lee,
thanks for the swift reply,
i've turned the security setting right down and the proxy was already turned off and i'm working directly on the server so i'm within the hardware firewall we have but still no luck!
Just wondering whether to start from scratch again?
jo woods
11 Jan 2007 11:04 AM
Seems strange that the installation says its complete but nothing happens on login?
Installing DotNetNuke
Version: 03.01.00
Current Settings
Default Provider SqlDataProvider
Connection String Server=(local);Database=DotNetNuke;uid=DotNetNukeUser;pwd=****;
.NET Framework Version 1.1.4322.2300
Windows User NT AUTHORITY\NETWORK SERVICE
Host Name ****
Installation Status Report
00:00:00.218 - Installing Version: 3.1.0
00:00:00.218 - Installing Script: DotNetNuke.SetUp.SqlDataProvider
00:00:00.249 - Installing Script: DotNetNuke.Schema.SqlDataProvider
00:00:02.140 - Installing Script: DotNetNuke.Data.SqlDataProvider
00:00:05.312 - Installing MemberRole Provider:
00:00:05.312 - Executing InstallCommon.sql
00:00:05.781 - Executing InstallMembership.sql
00:00:06.187 - Executing InstallProfile.sql
00:00:06.374 - Executing InstallRoles.sql
00:00:06.702 - Performing General Upgrades
00:00:06.921 - Loading Host Settings:
00:00:06.984 - Configuring SuperUser:
00:00:07.296 - Installing Desktop Modules:
00:00:07.296 - Installing Optional Resources:
00:00:07.296 - Installing Module File C:\DotNetNuke\Install\Module\Announcements_3.1_Install.zip:
00:00:07.796 - Installing Module File C:\DotNetNuke\Install\Module\Contacts_3.1_Install.zip:
00:00:07.984 - Installing Module File C:\DotNetNuke\Install\Module\Discussions_3.1_Install.zip:
00:00:08.187 - Installing Module File C:\DotNetNuke\Install\Module\Documents_3.1_Install.zip:
00:00:08.390 - Installing Module File C:\DotNetNuke\Install\Module\Events_3.1_Install.zip:
00:00:08.577 - Installing Module File C:\DotNetNuke\Install\Module\FAQs_3.1_Install.zip:
00:00:08.812 - Installing Module File C:\DotNetNuke\Install\Module\Feedback_3.1_Install.zip:
00:00:08.859 - Installing Module File C:\DotNetNuke\Install\Module\HTML_3.1_Install.zip:
00:00:09.062 - Installing Module File C:\DotNetNuke\Install\Module\IFrame_3.1_Install.zip:
00:00:09.093 - Installing Module File C:\DotNetNuke\Install\Module\Image_3.1_Install.zip:
00:00:09.234 - Installing Module File C:\DotNetNuke\Install\Module\Links_3.1_Install.zip:
00:00:09.437 - Installing Module File C:\DotNetNuke\Install\Module\NewsFeeds_3.1_Install.zip:
00:00:09.499 - Installing Module File C:\DotNetNuke\Install\Module\Survey_3.1_Install.zip:
00:00:09.749 - Installing Module File C:\DotNetNuke\Install\Module\UserDefinedTable_3.1_Install.zip:
00:00:10.124 - Installing Module File C:\DotNetNuke\Install\Module\UsersOnline_3.1_Install.zip:
00:00:10.249 - Installing Module File C:\DotNetNuke\Install\Module\XML_3.1_Install.zip:
00:00:10.281 - Executing Additional Scripts:
00:00:10.281 - Creating Portal: DotNetNuke Default Portal
00:00:14.234 - Successfully Installed Portal 0:
11 Jan 2007 11:06 AM
yes it seems odd, have you tried Firefox yet? www.firefox.com
jo woods
11 Jan 2007 11:19 AM
yes I've tried Firefox and its just the same. Could it be anything else? or would you delete my install of dotnetnuke and database and start again? its just seems so close!
11 Jan 2007 11:23 AM
I can't think of anything else off the top of my head, but it may be worth Googling around or looking in the main DotNetNuke Forum for any further possibilities.
have you set the folder for the DotNetNuke installation files with Read write permissions?
jo woods
11 Jan 2007 11:48 AM
I have been googling around but no luck so far. The DotNetNuke installation folder seems to have all the right read/write permissions...
Do I need to delete the ddn.config file?
Will keep looking tonight and then start again tomorrow I think...
Cheers,
Jo
jo woods
11 Jan 2007 11:52 AM
The last error i got was something about the URLRewrite and so I read the following from a forum and added the code and the installation went ahead.
"This error implies that there is already a "URLRewrite" HttpModule loaded in the application, so as your Virtual Directory is "/dnn_3_2_1" or something like that then "/" must contain an existing dnn install that is causing errors. I've had that problem setting up DNN in a virtual directory before. Specifically when a DNN installation is already running in the root dir of the webserver. The solution was to add the one line in between your line 58 and 59"
Maybe this has something to do with it?
Cheers,
j
11 Jan 2007 2:03 PM
hello,
I am unsure about any URL rewrite problems, I haven't come across those before.  It would also be worth your time posting a question in the main DotNetNuke Forum as someone else may have come across this problem before. Thanks,
jo woods
12 Jan 2007 8:31 AM
hi,
I tried posting on DotNetNuke Forum and then deceided to start the installation process again.
Now I get the following error: any ideas? i keep checking my permissions but all seem to have full access. My web config settings are
Thanks alot,
Jo
Upgrade Error: ERROR: Could not connect to database specified in connectionString for SqlDataProvider
Server Error in '/DotNetNuke' Application.
Could not find stored procedure 'dbo.GetHostSettings'.
Exception Details: System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.GetHostSettings'.
Source Error:
Stack Trace:
[SqlException: Could not find stored procedure 'dbo.GetHostSettings'.]
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream) +742
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior) +45
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(SqlConnection connection, SqlTransaction transaction, CommandType commandType, String commandText, SqlParameter[] commandParameters, SqlConnectionOwnership connectionOwnership)
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters)
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText)
Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, String spName, Object[] parameterValues)
DotNetNuke.Data.SqlDataProvider.GetHostSettings() +47
DotNetNuke.Entities.Host.HostSettings.GetHostSettings() +85
DotNetNuke.Services.Scheduling.SchedulingProvider.get_SchedulerMode() +5
DotNetNuke.Common.Global.StartScheduler() +8
DotNetNuke.Framework.Install.InstallApplication() +1213
DotNetNuke.Framework.Install.Page_Load(Object sender, EventArgs e) +274
System.Web.UI.Control.OnLoad(EventArgs e) +67
System.Web.UI.Control.LoadRecursive() +35
System.Web.UI.Page.ProcessRequestMain() +750
12 Jan 2007 9:09 AM
This error looks as though there is a problem with the connection string to your database, I would double check the connection string in your web.config file and also double check that you have created the SQL database with the username and password that you have specified in the connection string.
jo woods
30 Jan 2007 4:49 AM
Just to let you know, After rebuilding my server and putting a fresh install of sql and iis, I followed the TrainCert Install video and dotnetnuke loaded perfectly, amazing! It was easy after all!
Forums > DotNetNuke® > DotNetNuke® Questions > Installation Complete but unable to login
RE: HTML module not updating after transfer from localhost to live server by chrisoc
Hey guys,Thanks for the replies.   All seems to be working fine now.  I had previously cleared the b...
RE: w2k8 r2 - dnn site visible locally but not from internet by guyperrin
thanx joe. i just kept slugging away at this one. finally, when i gave IIS_IUSRS Full Control, i w...
RE: HTML module not updating after transfer from localhost to live server by jncraig
Check to make sure that you adjusted your portalalias table to point to the live site. It's possibl...
RE: w2k8 r2 - dnn site visible locally but not from internet by jncraig
Check to make sure that DNS points the site's URL to the web directory.  Your host ought to be able ...
RE: user retrieve password by giving email by jncraig
That should work. As with most things like this, I would recommend that you test and verify this ...
RE: Creating a new user by jncraig
DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the s...
RE: Email Verification by jncraig
Is this a question about Dynamic Forms? You can use Regular Expression validation to force the us...
RE: Issue 33 SQL updating page settings by jncraig
Can you describe the problem a bit more?
user retrieve password by giving email by raf948
I am using 4.8.0  and would like to have users retrieve password by giving their email ( as I unders...
RE: Change linkclick to document name by WinXnet
as far as I know, there is no way to not use linkclick other than to hard code the long url Selec...
RE: Skin missing banner and menu when ctl is used in the url by WinXnet
you're site appears to be down...
RE: DNN Live site not displaying by WinXnet
Is your site Properties in IIS > Documents > Enable default content page set to "Default.aspx"? E...
What version of DNN? Emerson ^_^
RE: Cross Portal Admins by WinXnet
Sorry for this post ^_^ My error - I got the password for the user wrong. Create user account ...
The menu is a module and it is set to publish on all pages. The HTML module is not set to publish t...
I have  situation where admins want to use the same login/password across multiple parent DNN portal...
RE: Issue 33 SQL updating page settings by pedrocapetillo
I have i similar problem and i am using DNN360 menu. Does anybody have information about that? Be...
Store module just refreshes page on "confirm order" by mike.hassinger
I have set up the store module with an Authorize.net account, set for authorize + capture. The check...
RE: logo token not functioning by WinXnet
I'm sure you've done this, but be sure you click on the "upload selected file" link under the Browse...
Is your menu a module as well? Is your banner HTML module set to "publish on all pages", or is it...
