Subject: Redirect to newly created control.
sandip
08 Feb 2006 10:48 AM
Dear Lee,
I want to redirect to my page after successfully registration. So I have created new page (web control into security folder.) Now I want link of that page so that I can use it into redirect function.  I have added new page into this location - \DNN\admin\Security\MyPage.ascx
Can you please tell me how to do this.
Thanking you,
Sandi
08 Feb 2006 10:54 AM
Hi Sandi,
To be honest I haven't programmed this before, so I don't know without researching it. - I would pop across to the DNN forums as someone must have already implemented this.
When you find the answer, let me know, I will be interested in reading the solution.
sandip
11 Feb 2006 1:21 AM
Hello Lee,
Here is more description about my problem... side by side i am looking on other forums... Meanwhile if you find  solution please reply me...
I have created control into admin/security/ folder and have added it as control into ‘User Account’ module. I have given key to this module as ‘RedirectOpt’  and its ascx is physically located at admin/security/RedirectOptions.ascx.
Now, I want to call this control on Page_Load event of register control. So I have added following code block in to register.ascx.vb.
Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Try
Response.Redirect(NavigateURL("RedirectOpt"))
Catch exc As Exception    'Module failed to load
            ProcessModuleLoadException(Me, exc)
      End Try
End Sub
Now it is redirecting to this http://localhost/DotNetNukedev/Home/tabid/36/ctl/RedirectOpt/Default.aspx link. But it is not the control, which I have created. On my control I have added some text boxes, and above link is showing blank page.
Can you please tell me how this is behaving. And how can I redirect to my control (RedirectOptions.ascx.). Though its key is right, it is not redirecting to my control so please tell me where it is going wrong.
Note: I have properly created RedirectOptions.ascx into admin/security/ folder and added some text boxes. So I am expecting redirection on this page and it should show my textboxes. When I keep break point on Page_Load event of RedirectOptions.ascx.vb, it is not going there, it means RedirectOptions.ascx is not getting called.
Also I have tried
Response.Redirect(EditUrl("", "", "RedirectOpt", ""))
Response.Redirect("Home/tabid/36/ctl/RedirectOptions/Default.aspx", False)
Response.Redirect("Home/tabid/36/ctl/RedirectOptions/Default.aspx", true)
All the time it is redirecting to the blank page.
I appreciate your quick reply.
Thanking you,
Sandi
sandip
11 Feb 2006 1:23 AM
Hello Lee,
Here is more observations…
 When I used
1) Response.Redirect(NavigateURL("RedirectOpt"))
 It is throwing expectation as “Thread was being aborted” but still redirecting to http://localhost/DotNetNukedev/Home/tabid/36/ctl/RedirectOpt/Default.aspx
 2) Response.Redirect(NavigateURL("RedirectOpt"), False)
It is not throwing any exception but redirecting to this blank page. http://localhost/DotNetNukedev/Home/tabid/36/ctl/RedirectOpt/Default.aspx
 3) Response.Redirect(EditUrl("", "", "RedirectOpt", ""))
It is throwing expectation as “Thread was being aborted” but still redirecting to http://localhost/DotNetNukedev/Home/tabid/36/ctl/RedirectOpt/Default.aspx?mid=-1
Note: Here reason may be it is not getting proper module ID.
4) Response.Redirect(EditUrl("mid", "75", "RedirectOpt", ""))
It is redirecting to http://localhost/DotNetNukedev/Default.aspx?tabid=36&error=Input+string+was+not+in+a+correct+format. And showing error on page "A critical error has occurred.
Input string was not in a correct format." Also throwing exception as “Thread was being aborted”
Please throw some light on it....
Thanking you,
Sandi
sandip
15 Feb 2006 9:11 AM
Hello Lee,
Found the solution... I remove the moduleid for my control and my above redirection start working... now it is working properlly on my live site too...
Sandi
15 Feb 2006 9:16 AM
Great, glad to hear you've managed to get it working, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > Redirect to newly created control.
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
