Subject: Error loading the custom module...
nirasha
29 Dec 2006 4:21 AM
I'm using dot net nuke installation version 4.3.5.
I need to upload the module packages to my production environment.
I created module packages with simple control and uploaded. But when i put that module to a page it gave me an error saying it's unable to load the control.
Then i check the relevant folder under "Desktop module"
Module name : PCC
i found the following folder structure
DeskTopModules -> PCC -> PCC
 under that it had it's controls.
Then i copied all controls to the parent PCC folder. Then it worked fine.
Please let me know whether i have missed anything here.
Note : I have copied the relevant DNN file packaged with that module
<dotnetnuke version="3.0" type="Module">
  <folders>
    <folder>
      <name>PCC</name>
      <friendlyname>PCC</friendlyname>
      <foldername>PCC</foldername>
      <modulename>PCC</modulename>
      <description>A test module</description>
      <version>01.00.00</version>
      <businesscontrollerclass>YourCompany.Modules.BLL.BLLController</businesscontrollerclass>
      <modules>
        <module>
          <cachetime>0</cachetime>
          <controls>
            <control>
              <src>DesktopModules/PCC/PCCMessage.ascx</src>
              <type>View</type>
              <helpurl></helpurl>
            </control>
          </controls>
        </module>
      </modules>
      <files>
        <file>
          <name>PCCMessage.ascx</name>
        </file>
        <file>
          <name>App_SubCode_BLL.dll</name>
        </file>
        <file>
          <name>App_Web_pccmessage.ascx.55c9c6a8.dll</name>
        </file>
      </files>
    </folder>
  </folders>
</dotnetnuke>
Nirasha
Forums > DotNetNuke® > DotNetNuke® Questions > Error loading the custom module...
