Subject: Removing View and Edit Buttons
mikehj
15 Mar 2010 8:57 AM
I have removed the Register and Login controls from the default page. I still have the Edit and View buttons visible at top of page. Is there any way to remove or hide them from default users. This will be used on a public accessible web site in which we do not wish to display any login or register artifacts.
jumatthey
15 Mar 2010 9:54 AM
Can you post a screeshot of what you are refering to more precisely ?
Thanks. I personnaly removed the register link from my pages. For this I went into my template skin file and removed the register tag. The skin file was to be found in "portals/_default/Skins/YourSkin/YourSkinFile". Tags are < dnn:user > and < dnn:login >.
mikehj
15 Mar 2010 10:11 AM
I was able to remove the register in admin settings and I had already gone into the skins file and made the change you suggested. After that I was left with the View and Edit button as displayed in the attached PDF file
Attachment: 1315113229671.pdf
jumatthey
15 Mar 2010 10:32 AM
o.O ... weird.
This should only display if you are logged on as admin or host.
15 Mar 2010 10:34 AM
Most likely, the View and Edit buttons are there because either the page or a module on it has edit permissions for other than Administrators. Check all of the permissions.
mikehj
17 Mar 2010 9:48 AM
Joseph - you are right on the money. I missed a security setting on the page. Thanks
Forums > DotNetNuke® > DotNetNuke® Questions > Removing View and Edit Buttons
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
DNN Creative Subscribe
