Subject: Error: Thread was being aborted - Install
Marcusw
20 Dec 2006 7:10 AM
When doing a new install of DNN (version 4.3.7) I get the error message "Error: Thread was being aborted" towards the end of the install script.
00:02:07.012 - Executing Additional Scripts:
00:02:07.012 -   Creating Portal: My Website
00:02:18.378 -   Error: Thread was being aborted
It appears to have got past the module installs but always falls over here.
Anyone got any ideas?
Cheers,
Marcus
Forums > DotNetNuke® > DotNetNuke® Questions > Error: Thread was being aborted - Install
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
