Subject: meta tag
claude
23 Jun 2009 10:07 AM
Where can i find my  home page HTML , I like to add some meta tag?
Claude
24 Jun 2009 12:54 PM
You can add meta tags using the Page Settings for a particular page.
If you want to add meta tags to every page, you'll want to modify Default.aspx, but it will insert the meta tag on every portal. It will also disappear if you upgrade, so remember to keep a copy.
I can't recall if you can add meta tags in skin files, so you'll want to check on those.
claude
24 Jun 2009 8:13 PM
Thanks Joe ,
I want to put a meta tag from google to be verified for the search engine
26 Jun 2009 6:30 AM
quickest way for the verification code from Google is to go to your home page / page settings / advanced settings
and page header tags
in there paste the code from Google
scroll to the bottom, click update
RE: Plz Help. Page_Load_Exception by zaidkhan
URL of My website is www.pafkiet.edu.pk
Few new skins by Rozo
Skins for DNN and other CMS. www.stelg.com
RE: Plz Help. Page_Load_Exception by jncraig
Can you provide a URL?
RE: Custom Textbox Size by jncraig
For the second part, you can switch the editor to source mode and enter unstyled text. For the fi...
RE: Picture size limits by jncraig
The little red x's generally mean that the link to the image is broken.  My guess is that you have a...
RE: Uploading an MP3 file to my website by jncraig
web.config is in the root directory of your DotNetNuke installation.  ALWAYS (!!) make a backup copy...
RE: Customizing registration page by kana
Picture size limits by Doug_s
I'm lost - I've just changed host and a few thing that used to work don't, plus I can't display anyt...
RE: How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50 by samjst
Hi, Did you manage to solve the problem? I'm facing the same issue: users with access to add and...
Ealo Tab Localization help by sadabahar83
hi, I have installed Ealo Core Api and Ealo tab localization and ealo Menu provider. menu is wor...
Custom Textbox Size by PopeOMalley
Hello everyone,Do you know if there is a way to customize the size of a textbox control on the Manag...
RE: DotNetMushroom RAD by md-pv
That sounds interessting too. I'll check it. Thanks a lot.
thanks alot for replying Sir,Well.. my Under Construction Redirect issues are more general and they ...
RE: Uploading an MP3 file to my website by billkidwell
Joseph - I added the mp3 extenison to the list. It still diod not work. No error message but it did ...
Two things could go wrong.First, mp3 might not be an allowed file type.  You should have received an...
Joseph - Thanks, but I see my post was unclear. I tried to upload the MP3 and teh uplaod failed. No ...
RE: What are best tools for localization? by jncraig
The modules from Apollo and the EALO and Magic Content modules are the ones that I would use.  I don...
RE: Customizing registration page by jncraig
You can add three fields to the user profile as you describe.  No coding is required.  Look at the M...
RE: Different skins based on browsers by jncraig
The Minimal Extropy skin that is distributed with DotNetNuke 5 includes the functionality that allow...
RE: DotNetMushroom RAD by jncraig
SGSV is "SQL Grid Selected View" if I remember correctly.  It is from Tressleworks.ca.  It is very i...
