| RE: Reseller Choice by RC-Rob |
| alread, Please dont misslead people.
The correct URL to ResellerChoice is http://www.resellerchoi... |
| RE: Orizonti vs. Novus ? by gbrown |
| I have the Orizonti RSS module. I also have the Xmod RSS module. But I think the best RSS module... |
| RE: Reseller Choice by alreadyalread |
| Posted By Lee Sykes on 10 Aug 2005 5:33 PMI can recommend Reseller Choice, there have been a couple ... |
| Create dnn package like store module by lakmal |
| Hi,I am going to create module like dnn store module. I
have created seperate project inside dnn we... |
| RE: UnderConstruction Message by soupy6667 |
| I have used my host's online SQL tool to access the database using the username and password from ... |
| RE: UnderConstruction Message by jncraig |
| Do you have access to SQL Server Management Studio, or some other tool that you can use to connect t... |
| Hi Joe,
Yes the site was working fine after I installed the skins. I even set the site back to th... |
| It the site was working after you installed the skins but is not working now, I might suspect the co... |
| Hi All, (Merry Xmas)
I had DNN 5.2.1 installed on a host service (dotnetpark) as I was having pro... |
| Orizonti vs. Novus ? by tcse |
| Hello Lee, Great tutorial on setting up and using Orizonti, I went to snowcovered.com and started lo... |
| RE: why is my DNN based website so slow ? by Kazi |
| Hello Rana, I think I can fix or diagnose this problem for you, please send your login info to info@... |
| RE: Object reference error: UpdateTabModuleSetting(Int32 TabModuleId, String SettingName, String SettingValue) by majd_wadi |
| Thanx for your reply.the dnn version is 05.02.01and the module's version is 05.00.03.i made a postin... |
| RE: Object reference error: UpdateTabModuleSetting(Int32 TabModuleId, String SettingName, String SettingValue) by jncraig |
| Versions, please. Which version of DotNetNuke do you have after the upgrade? Which version of ... |
| hay all, i have the latest dnn version, i've just upgraded it.anyway, i inistalled Form & List modul... |
| RE: why is my DNN based website so slow ? by ranasrule |
| I have tried both caching and Heavy caching...doesnt make any differenceIm willing to provide host ... |
| RE: why is my DNN based website so slow ? by jncraig |
| What settings do you have under performance? Are you caching? Heavy caching? You're secondary p... |
| RE: File Manager DNN 5.1.2 by oli.loftus |
| The post has now been moderated and I am linking below:http://www.dotnetnuke.com/Community/Forums/ta... |
| I'm having an identical problem in my DNN portal. I'm running DNN 5.2.0 on a Vista machine. I'm trie... |
| RE: Update Module Directory by johannf |
| The option I'm planning to go for is NB_store.
Catalook is also a option, but it seems very comple... |
Hi everyone.....Im really in a bind here....i just setup a
websit... |
