| RE: How to use the DNN Feedback module as a simple Contacts Form by jncraig |
| Those 4 items are included in the message and the one sent to the moderator. Perhaps I'm not unders... |
| RE: Links by jncraig |
| "Host" skins can be applied to any portal within the installation. "Site" skins can be applied only... |
| RE: Links by rajanijadhav |
| Thanks sir.I have solved the problem by adding pointer for already running web site. I have anothe... |
| RE: How to use the DNN Feedback module as a simple Contacts Form by crsqn91l |
| hii want to send email with feedback module entered name, email id, subject, message after submitti... |
| RE: Error: Host Settings is currently unavailable. by jncraig |
| If there is a version of DotNetNuke to which you can safely revert, then I would do that first. The... |
| RE: DotNetNuke & SQL 2008 by jncraig |
| What is the story with the port numbers? Are you actually running this in Visual Web Developer and ... |
| RE: Error: Host Settings is currently unavailable. by msrwindermere |
| Hi Joseph,
This is the error I receive when I tried the upgrade:
Compilation Error
Description... |
| RE: DotNetNuke & SQL 2008 by AlexDe |
| Thank you for the remark. Unfortunatelly the replay is same "The webpage at http://localhost/ might... |
| Since 4.6.2, you don't have to manually edit web.config. That should make upgrading a simple proces... |
| Hi Joseph,
Thank you for your reply. Sorry I haven't been able to respond quicker. My first attem... |
| FTP website using DNN by stoyan |
| Hi everybody and Happy New Year, I searched the forum but I did not find the answer.I use one of my ... |
| Store Module - Customize Billing & Shipping Address by CBOSS |
| Using the DNN store module is there anyway to change the "region" label to "state"?
Is there a way ... |
| RE: House Menu version 1.4.1 by jncraig |
| You can create a "page" that is a link to an external URL. Set this in the page settings. It will ... |
| RE: organizing images and photos in portal by jncraig |
| You can certainly use ftp.If you put files in the installation's root directory, they will be visibl... |
| RE: Creat a custom Login & Registration Module. by Vimala |
| Hi friend,
I missed out small logic to think. Now I cleared the redirect issue.
Its really a... |
| RE: send user properties by forms by polyvan |
| Happy new year and many thanks,i'll try this.Best regards. |
| RE: organizing images and photos in portal by micki |
| thank you... i had assumed that if i .ftp'ed the folders of files to the root that they would show u... |
| House Menu version 1.4.1 by micki |
| another question...is it possible to add an external link to the house menu module? sorry to ask suc... |
| RE: Advice on catalog module by shraga |
| Thanks you, Joe. From the demos of the module it indeed looks like a good possibility for this proj... |
| RE: Advice on catalog module by jncraig |
| Ventrian's Property Manager might be something to look at. |
