| RE: Site taking a long time to load by leesykes |
| You may also want to have a look at:Performance Tips - Fast Site - Keep Alive Tools - Hosting |
| RE: How to put DotNetNuke local site live? by leesykes |
| Hello,You may want to view:How to transfer a localhost DotNetNuke installation to a live websiteFind... |
| RE: FCKeditor Tutorials by leesykes |
| nice one, I will have to remember that one! |
| RE: FCKeditor Tutorials by RickMontana |
| You got me thinking about the DOC types so I did some poking around and found an entry in the FCKcon... |
| RE: HTML/Text Editor Bombs on Site Running 4.3.5 by jncraig |
| From the error message, the problem appears to be with the file DesktopModules/HTML/EditHTML.ascx. ... |
| RE: HTML/Text module not available by leesykes |
| Just to follow up, there is a new configuration in DNN 5 for this:Go to the admin menu / extensionsn... |
| RE: Email Problem with FCKEditor by leesykes |
| Ken, are you still having problems with this? It shouldn't affect it having Custom Editor OptionsFro... |
| RE: iHostASP by Argel |
| I second the thanks. As a user of the cheapest package I've found it relatively easy to set up and m... |
| RE: How to Create a Portal Signup Module with OWS - Issue 51 by pauldes |
| OK, all. I was using a prerelease version of 2.1.18 to describe this new feature which I was told wa... |
| RE: HTML/Text Editor Bombs on Site Running 4.3.5 by leesykes |
| it's hard to know if an upgrade would fix the problem, however as long as your hosting provider crea... |
| FREE Menu Box by coding-staff |
| Coding Staff is proud to announce a release of FREE Menu Box version 1.00.04
Coding Staff presents... |
| RE: HTML/Text Editor Bombs on Site Running 4.3.5 by Mr. Chip |
| Hi Lee, Thanks for the suggestion. It would be a bit difficult for me to install locally due to ... |
| RE: can not delete a text/html module by tiktacs |
| Thank you very much. |
| RE: ASCX and MSVWD by leesykes |
| ok, I just checked it in DNN 5.1.4 and intellisense works for me using VWD Express 2008.I opened the... |
| RE: File Manager DNN 5.1.2 by leesykes |
| I guess so . . . It looks like it is another "trick" that we need to look out for and I guess the fi... |
| Ok, I understand now, I think I have come across this problem before as well. When doing any admin e... |
| RE: Skin not working with Aweber in IE8 by leesykes |
| Using Datasprings dynamic forms, it sends the details directly to Aweber, so it is using the service... |
| RE: Where do we get help skinning DNN 5.x? by leesykes |
| Thanks, If you come up with any particular tips or elements you think I should be exploring, please ... |
| I would create a backup of your website and install it on your local computer. From there you can tr... |
| Hello,I have a "secondary" DNN site that I have neglected for some months. I went to start working ... |
