Subject: Dnn - SQL 2k
arthursc
04 Jan 2006 1:33 PM
Hi Lee,
Get this error when running ctrl + F5 to build dnn;
            <pre>[NullReferenceException: Object reference not set to an instance of an object.]
            DotNetNuke.Common.Utilities.Config.GetConnectionString(String name) +49
            DotNetNuke.Data.SqlDataProvider..ctor() +126
            [TargetInvocationException: Exception has been thrown by the target of an invocation.]
            System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean&amp; canBeCached, RuntimeMethodHandle&amp; ctor, Boolean&amp; bNeedSecurityCheck) +0
            System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) +103
            System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) +261
            System.Activator.CreateInstance(Type type, Boolean nonPublic) +66
            DotNetNuke.Framework.Reflection.CreateObject(String TypeName, String CacheKey, Boolean UseCache) +233
            DotNetNuke.Framework.Reflection.CreateObject(String ObjectProviderType, String ObjectProviderName, String ObjectNamespace, String ObjectAssemblyName, Boolean UseCache) +571
            DotNetNuke.Data.DataProvider.CreateProvider() +39
            DotNetNuke.Data.DataProvider..cctor() +13
            [TypeInitializationException: The type initializer for 'DotNetNuke.Data.DataProvider' threw an exception.]
            <font style="BACKGROUND-COLOR: #ff0000">DotNetNuke.Common.Globals.GetUpgradeStatus() +331
            DotNetNuke.Common.Global.CheckVersion() +188
            DotNetNuke.Common.Global.Application_Start(Object Sender, EventArgs E) +322</font>
            </pre>
            <pre>(in red is this an issue?)</pre>
            <pre>IN Addition web.config is;</pre>
            <pre><font color="#0000ff" size="2">
            <p><<font color="#800000" size="2">connectionStrings</font><font color="#0000ff" size="2">>
            <p><!--<font color="#008000" size="2"> Connection String for SQL Server 2005 Express </font><font color="#0000ff" size="2">-->
            <p><!--<font color="#008000" size="2">add
            <p>name=&quot;SiteSqlServer&quot;</p>
            <p>connectionString=&quot;Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|Database.mdf;&quot;</p>
            <p>providerName=&quot;System.Data.SqlClient&quot; /<font color="#0000ff" size="2">-->
            <p><!--<font color="#008000" size="2"> Connection String for SQL Server 2000/2005</font><font color="#0000ff" size="2">-->
            <p><<font color="#800000" size="2">add</font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></p>
            <p><font color="#ff0000" size="2">name</font><font color="#0000ff" size="2">=</font><font size="2">&quot;</font><font color="#0000ff" size="2">dnntriumph</font><font size="2">&quot;</font></p>
            <p><font color="#ff0000" size="2">connectionString</font><font color="#0000ff" size="2">=</font><font size="2">&quot;</font><font color="#0000ff" size="2">Server=(kess);Database=dnntriumph;uid=XXXXXXXX;pwd=XXXXXXX;</font><font size="2">&quot;</font></p>
            <p><font color="#ff0000" size="2">providerName</font><font color="#0000ff" size="2">=</font><font size="2">&quot;</font><font color="#0000ff" size="2">System.Data.SqlClient</font><font size="2">&quot;</font><font color="#0000ff" size="2"> />
            <p>&nbsp;</p>
            <p></<font color="#800000" size="2">connectionStrings</font><font color="#0000ff" size="2">>
            <p><<font color="#800000" size="2">appSettings</font><font color="#0000ff" size="2">>
            <p><!--<font color="#008000" size="2"> Connection String for SQL Server 2005 Express - kept for backwards compatability - legacy modules </font><font color="#0000ff" size="2">-->
            <p><!--<font color="#008000" size="2"> add key=&quot;SiteSqlServer&quot; value=&quot;Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|Database.mdf;&quot;/</font><font color="#0000ff" size="2">-->
            <p><!--<font color="#008000" size="2"> Connection String for SQL Server 2000/2005 - kept for backwards compatability - legacy modules</font><font color="#0000ff" size="2">-->
            <p><<font color="#800000" size="2">add</font><font color="#0000ff" size="2"> </font><font color="#ff0000" size="2">key</font><font color="#0000ff" size="2">=</font><font size="2">&quot;</font><font color="#0000ff" size="2">dnntriumph</font><font size="2">&quot;</font><font color="#0000ff" size="2"> </font><font color="#ff0000" size="2">value</font><font color="#0000ff" size="2">=</font><font size="2">&quot;</font><font color="#0000ff" size="2">Server=(kess);Database=dnntriumph;uid=XXXXXXXXX;pwd=XXXXXXXX;</font><font size="2">&quot;</font><font color="#0000ff" size="2">/></font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></p>
            </font></pre>
Any Ideas....Thanks.
04 Jan 2006 1:56 PM
Have you added the database to your SQL server and added the Username
you have specified in your connection string to your SQL server database?
You also need to give the User of the database the correct permissions - ie. owner permissions.
Have any tables been added to the database?
If you receive errors when first installing I always wipe everything, all files & the database and then re-install
to ensure I get a completely clean installation. - So I would do this once you have worked out what the problem is.
Let us know how you get on and what the problem was.
If you think you have done all of this correctly try the asp.net forums in the Getting Started section
as there are many people on there that may have come across similar problems when installing for the first time.
Web.config Error by derpir
Yahoo Answers by cdtguru
RE: Videos by clippy
skinning trouble by derpir
RE: Template Issue by jncraig
RE: Style sheet does nothing by andorz
Oh. I was told to do that in my thread at the dotnetnuke.com forum. http://www.dotnetnuke.com/Commun...
