Subject: Mdoules:Creating&Searching (For specific modules)
tiktakit
05 Sep 2006 2:34 PM
I'm now starting to investigate the modules section more deeply.
First I'd like to know if there's a document of how to write a module.
Second, i'm looking 4 a news module. I was searching long on the web for this kind of module:
http://www.best-bpc.com/web/content/
(news and updates)
The news titles appear in the front page and the full article reveals when clicking on item. Also there is this kind of page:
 http://www.best-bpc.com/web/content/listofnews.asp
which is less importent.
Since i wrote the system above, I'll be able to adjust it so it will be a module - but i need to know how (espcially how to work with the DB's of the DNN - how can i know which there are?..)
A reay module (free or not) is a better option for me, which I also believe that exists (somewhere).
I'll be happy to receivie some reliable links for modules.
I tried this one:
http://www.efficionconsulting.com/Default.aspx?tabid=352
but after installing it, when i try to use it and add a new article from the container that contains this module i get this error:
  An error has occurred.
Error Adding or Editing Article
so.. didn't work for me :\
thanks!
thanks!
06 Sep 2006 2:38 AM
I have not created any tutorials on creating modules, but I have a page of resources to other sites with tutorials on this:
http://www.dnncreative.com/tabid/125/Default.aspx
News modules, check out the reviews of the various news modules:
http://www.dnncreative.com/Reviews/Modules/NewsandArticlesModules/tabid/60/Default.aspx
Scott McCulloch's and Orizonti's news modules should cover your requirements that you mention.
Forums > DotNetNuke® > DotNetNuke® Questions > Mdoules:Creating&Searching (For specific modules)
