Subject: Can't Install housemenu module
tiktakit
03 Sep 2006 6:23 AM
I tried to install housemenu module.
In the first installation I had some problems, but i didn't find where i culd remove it - so i just re-installed it again, this time with no errors.
But when I used the [HOUSEMENU] token, including the suitble modifications in the XML page, it just appear on the skin like this: "[HOUSEMENU]".
So i realized the module is not "parsed", and i checked in host->module definitions->[skin objects] to see what tokens are defined, and didn't find housemenu.
I used "Add control" button to add it, i found two house menu in the list: housemenu and housemenuOptions. I added both, but only to housemenu i added the key "[HOUSEMENU]".
Still doesn't work, the token is appeared as text and is not parsed. What to do ?
Thanks in advance,
Hadar
tiktakit
03 Sep 2006 6:45 AM
Problem solved.
What I DIDN'T do is to re-install the SKIN. So now i figure that after i upload or change module definitions, I also need to re-install all the skin and not only refresh the page - because the DNN parse the ascx file differently.
Anyway, it was a taugtful experience! (if one of these words exist...)
Forums > DotNetNuke® > DotNetNuke® Questions > Can't Install housemenu module
