Subject: XMod 3.2 Module
radhakrishan
03 Jan 2006 5:11 AM
Just want ur advice/suggestion on this.
Is XMod good module for creating customized dotnetnuke modules. Or can you suggest any other good modules .... (for developing customized dotnetnuke modules).
Regards
03 Jan 2006 5:20 AM
XMod is a good module, but I haven't used it since version 1.
What I did find was that XMod worked well up until a certain point where I needed to add more advanced features, from this point I then had to re-think my approach and in every case I resorted to creating my own modules.
If XMod fits your needs you will find it to be a big timesaver once you have learnt how to use XMod. - It can be slightly complicated to learn for beginners, but the support from the developer is really good.
I have not come across any other modules that work in a similar way to Xmod.
04 Jan 2006 3:31 AM
I've just found this module which maybe useful for creating customised forms:
http://dnn310.ucanuse.com/PortalModules/UserAttributes25/tabid/57/Default.aspx
