Subject: Is the site size of DNN actually 999 Megs?
qibingyue
30 Aug 2006 10:31 PM
I want a maximum larger than 999M !    If  I can edit the database by hand ?
And which keywords in  database  for me  to modify?
Thans!
31 Aug 2006 2:34 AM
This is a problem with the older versions of DNN - in DNN 4.3 / 3.3 this has been fixed so that you can enter a value up to 999999.
Also if you want unlimited space, enter the value 0 - so try entering 0
Be aware: - The older versions of DNN will develop errors if your disk space goes beyond 2GB. - Errors will occur for the File Manager meaning that you can no longer select files within modules or upload / view files in the File Manager. - This is also supposed to be fixed in 4.3 / 3.3.
Forums > DotNetNuke® > DotNetNuke® Questions > Is the site size of DNN actually 999 Megs?
