Subject: DNN 4.3.4 skins and containers
ekveeneman
28 Aug 2006 7:47 AM
I went through the 'Quick Start Guide' and noticed that there were more skins and containers available than the ones I have for DNN 4.3.4. I have only the blue and gray options in each. Am I missing something ? Thanks for your help.
31 Aug 2006 2:37 AM
Yes this is correct, if you want to download several skins, download the old DNN3.0.13 release from here:
http://prdownloads.sourceforge.net/dnn
This release included several skins. - They stopped including these skins because it increased the size of the zip file for download.
ekveeneman
05 Sep 2006 7:59 AM
Thanks, Lee. I appreciate the link.
Forums > DotNetNuke® > DotNetNuke® Questions > DNN 4.3.4 skins and containers
