Subject: PageLoad error event
jamesc
28 Aug 2006 7:14 AM
I am getting the following error in the log viewer.  The page reders okay, and the error only occurs in the parent portal.  None of the child portals is reporting this error.  The skin is defintely in the directory mentioned in the error log.  Any help appreciated.
AssemblyVersion: 04.03.03
PortalID: 0
PortalName: Portal Home
UserID: -1
UserName:
ActiveTabID: 1111
ActiveTabName: Home
RawURL: /default.aspx
AbsoluteURL: /default.aspx
AbsoluteURLReferrer:
UserAgent:
ExceptionGUID: aa41dace-d844-4842-8032-31a8d0e7976d
InnerException: Unhandled error loading page.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Web.UI.Util.CheckVirtualFileExists
StackTrace:
Message: DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.Web.HttpException: The file '/Portals/_default/Skins/xHorVerMenu_Prod/PortalStandard.ascx' does not exist. at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.Framework.DefaultPage.LoadSkin(String SkinPath) in E:\WebSites\Stage\Hydro\Default.aspx.vb:line 223 --- End of inner exception stack trace ---
Source:
Server Name: RUTABAGA
Forums > DotNetNuke® > DotNetNuke® Questions > PageLoad error event
