Subject: Menu Bug in Firefox??? (menu up 1px on rollover???)
jasonwsaz
25 Aug 2006 10:33 AM
When viewing a dotnetnuke website in Firefox the menu word move up 1px on rollover.  It doesn't do this in Internet Explorer...Any suggestions?
Jason
Forums > DotNetNuke® > DotNetNuke® Questions > Menu Bug in Firefox??? (menu up 1px on rollover???)
