Subject: Panes width
DNNFLO
25 Aug 2006 5:17 AM
I'm working on DNN sites installation and skin design, a little...
One of my user is asking me for a fixed width for the different panes ( as to say, the 3 main :left, content and right panels..) using a percentage, for allowing resizing when different screen resolution. I did it by using css classes :
.leftpane
width="20%"
.contentpane
width="60%"
.rightpane
width="20%"
When the page is empty, everything is ok, but when he adds a module in the left pane for example, this pane extends to more than the percentage fixed in the css......
What can be done to get every module added in a pane respecting the width attributed to the pane ?
Thanks a lot for your help,
25 Aug 2006 6:10 AM
What you need to be careful of is the length of the titles for the containers that you add.
For instance if you add a container with a title that is wider that the 20% width, it will force the skin to display the left pane wider than you intended.
The same goes for the content that you add, if you place an image inside your text/html module that is wider than 20%, again this will force the left pane to display wider than intended.
You can't force a container title to go to the next line if it is too wide, the only way to do this is to add break tags into the title.
DNNFLO
25 Aug 2006 7:03 AM
Ok, I understand.
Thanks a lot for your quick answer.
