Subject: Come here! LEE
qibingyue
24 Aug 2006 8:31 PM
Thank u for  your kind help .
Now another question annoy me.   I want to  put a great deal of  <script> language="JavaScript" type="text/javascript"> rwWord("staff"); </script> staff informations in to the SQL database.   Do u have any good idea?
Thans a lot!
25 Aug 2006 3:10 AM
Well, this is where you will need to create your own custom modules. There are no tutorials on DNN Creative for this, but there are links to various tutorials on this page:
DotNetNuke Resources
qibingyue
26 Aug 2006 8:46 AM
But where are the links,I can't find it!
And now , i want to use SQL sentence to put the staff informations into SQL database. U know, there are a lot of tables in database.,I really don't know how to do it! .
Help me !
28 Aug 2006 5:46 AM
That page provides a list of links to various articles on other DNN websites which help you to create a module. - This is what you need to learn to set this up.
