Subject: DNN css skins with 'ems' as font size
oakley
24 Aug 2006 5:02 PM
I've been writing a series of pure  css skins using relative font sizes - ems.. and having a few problems.
Is there anyone who has implemented ems throughout their skins who can give advice..
25 Aug 2006 3:16 AM
I can't give advice on ems, but I can on using percentages. - I previously used ems before switching to the percentages method and I find using percentages much easier to conifgure and maintain.
You can watch a tutorial on how I configured this here:
How to create a pure CSS skin
and you can view the skin that implements this from:
Free Skin - Simple Red Leaf CSS Skin
Forums > DotNetNuke® > DotNetNuke® Questions > DNN css skins with 'ems' as font size
