Subject: SIFR
manofvalor24
22 Aug 2006 7:42 PM
Does anybody know if sifr works with the latest version of DNN. Also, does it work with non css layouts?
I am using DNN 4.3.4 and I followed the tutorials exactly and sifr doesn't work for this version. When I put the javascripting in the default.aspx file I get an http 404 error and my page won't load anymore.
If anybody knows anything about sifr I would appreciate it very much. I really like the idea of using it for my headings and sub headings.
23 Aug 2006 3:42 AM
Thanks for bringing this to my attention, if you now visit the sIFR tutorial page I have added in some additional steps for configuring it with DNN 4.3.4.
sIFR will work with table based layouts, as long as you set it up using the same method for your titles as outlined in the tutorial.
manofvalor24
23 Aug 2006 10:51 AM
Lee,
Thanks a lot for your response. It worked out.
This site has saved my life so many times. Thanks again!
23 Aug 2006 12:06 PM
No problem, glad to hear you got it working. Let us have a look at the site when you have it complete, I'm always interested to see how people have implemented sIFR,
Cheers,
manofvalor24
24 Aug 2006 3:49 PM
Lee,
Here is the site. Keep in mind, I only created the skin for the client. So the client hasn't put any content on it yet.
http://partnershipforrevival.org/Home/tabid/36/Default.aspx
25 Aug 2006 3:26 AM
Thanks, it's great to see a site using sIFR, it makes such as difference to have the titles styled using a nice looking font!
Cheers,
