Subject: links doesn't appear in site
tiktakit
22 Aug 2006 3:14 AM
Hi again.
I'm having trouble displaying my site links (im not using the [LINKS] module).
Im using this styles:
.CommandButton
    font-family: Tahoma, Arial, Helvetica;
    font-size: 13px;
    font-weight: normal;
a.CommandButton:link {  color: #294F90; text-decoration: none }
a.CommandButton:visited {  color: #294F90; text-decoration: none }
a.CommandButton:hover {  color: #DB031B; text-decoration: none}
a.CommandButton:active {  color: #294F90; text-decoration: none }
and i have normal links in my page, meaning: <a>some link</a>.
I read on your styling tollkit that all the links, including the links in the CSS that i get thorugh the "Site Settings" menu, should be ordered by link,visited,hover,active.
I changed all the references to the a. styles so it will be ordered correctly, im my CSS and in the site CSS. Unfortunatly, the skins still does not appear.
Did i miss something ?
Hadar
22 Aug 2006 3:39 AM
Which links are you trying to style?
The link, visited, hover, active order is important if you wish the active state to work. - It will not affect being able to actually style the links.
The styling mentioned above will just style any links that are in the CommandButton class.
If you want to style links for instance in the Text/HTML module, you need to style the Normal Class:
.Normal A:link, .Normal A:visited, .Normal A:active
    text-decoration: none;
    color: #036;
.Normal A:hover
    text-decoration: underline;
    color: #F00;
tiktakit
22 Aug 2006 4:47 AM
how about links that are not inside a module?
this one doesn't work:
a:link { color: #294F90; text-decoration: none }
a:visited { color: #294F90; text-decoration: none }
a:hover { color: #DB031B; text-decoration: none}
a:active { color: #294F90; text-decoration: none }
22 Aug 2006 4:58 AM
It depends which links you are trying to style, for instance for the login links, have a look at:
http://www.skinningtoolkit.com/SkinObject/tabid/93/Default.aspx
Does this help?
Do you have a URL?
tiktakit
22 Aug 2006 5:21 AM
In my skin, I added link. Its a footer; I want to add some links at the footer of the skin, currently without using the [LINKS] module.
So these are just regular html links - its not in a module or something.
url :http://h.dnn.selfip.com/%D7%A1%D7%A7%D7%99%D7%A8%D7%94%D7%97%D7%95%D7%93%D7%A9%D7%99%D7%AA/tabid/132/Default.aspx
the kinks should appear at the botoom, on the right to the small printer menu icon.
22 Aug 2006 5:36 AM
Thanks for the URL, looking at your skin, the a:link css does work. - If you change the styling of those it changes the colour of the links for the text  "Created by - Target Advanced Webs "
I don't see any links to the right of the printer icon though. - Am I mis-understanding what you are trying to do?
Can't you just set up your links exactly as you have done for the "Created by - Target Advanced Webs" text in your skin?
Or - do you wish to add links from a DotNetNuke page? - If you do why don't you just use a Text/HTML module? - If you want to style them differently to the normal class then put a div tag around them and give them a different CSS class.
22 Aug 2006 5:37 AM
or try specifying the class directly within the a tag ie. < a class="mystyle" href=" .. .. etc.. ..
tiktakit
22 Aug 2006 5:41 AM
That's just the problem - there should be links next to the printer icon! it just disappeared from the skin!
i think that in a moudle it not very convinient because i'll need to duplicate my module to each page. I want the links automatically in the skin...
I'll try to do it as u said with the "created by..". I'll keep u posted ;)
tiktakit
22 Aug 2006 5:49 AM
The problem is more sevear than i thoguht: It can't display links in hebrew! what should i do ? All the links are in hebrew. I changed on the english and it appeared. That's a serious bug for me. Do u have suggestions ?
22 Aug 2006 6:03 AM
Looking at the source code, these 3 links:
/Portals/_default/Skins/compass/www.yahoo.com
Just have blank spaces where the text should be for the links - are these the links that you are trying to create?
Are you creating your skin using a .htm and skin.xml file. - Perhaps something is happening when DNN is parsing the skin.
I would try editing the your .ascx file direct that is on your DNN portal and see if that displays the hebrew.
tiktakit
24 Aug 2006 5:57 AM
yes - that's the links. i tried to edit the ascx files, which the links were really missing in - didn't help. I added them manually, i checked im editing the right file (other things DID change) but it doesn't show up hebrew. i dunno what to do..
24 Aug 2006 7:52 AM
I think the only option you have left is to add a text / html module to the footer and then add your links in and then set the module to display on all pages. - The hebrew links work in the main content area, so this doesn't really make sense why they would disappear when you add then directly to the skin.
Forums > DotNetNuke® > DotNetNuke® Questions > links doesn't appear in site
