Subject: SQL Injection Attack
Kc Kong
15 Oct 2008 9:44 PM
Hello, We had recently experienced a SQL injection attack. I have changed the SQL DB password and did appropriate changes. But somehow the residual of the attack still remained. The attacker basically injected, [script removed]" when I view the page source. I am wondering could anyone point to me what tables/stored procedures that I should look for in order to completely remove the injection scripts. Any information will be greatly appreciated! Regards, KC
17 Oct 2008 7:42 AM
I don't have any suggestions other than to dig through the database and look for stuff that shouldn't be there.
Forums > DotNetNuke® > DotNetNuke® Questions > SQL Injection Attack
